Stopping the server or reconnecting without killing Fusion
TRIALCAD2014
Message 1 of 8
TRIALCAD2014
every now and then, sometimes 10 times a day when I try to run a script in debug I get this message.
WHen I click Cancel the server stop button in VS is  not available. In Fusion I can still run the script but if If I try to re-launch in debug I get the same message.
Only stopping and restarting Fusion works ut there must be a less dramatic way to either reattach or stop it.
I even tried to hunt down the pid but nothing worked.
Thank you,
Adrian
Replies (7)
Message 2 of 8
kandennti
Hi @TRIALCAD2014 .
I would like to know how to do it too.
In the end, the only way I can figure out how to fix it is to restart Fusion360.
Message 3 of 8
j.han97
What happened before this error?
From my experience there usually are two reasons:
1. The add-in is still running and I tried to run the add-in again.
2. There is another script/add-in in debug mode.
 I'm interested in experimenting with this if you can provide a way/description to reproduce your exact situation.
Message 4 of 8
TRIALCAD2014
I modified my setting to
"version": "0.2.0",
"configurations": [
"name": "Python: Attach using Process Id",
"type": "python",
"request": "attach",
"processId": "${command:pickProcess}"
"name": "Python: Attach",
"type": "python",
"pathMappings": [
"localRoot": "${workspaceRoot}",
"remoteRoot": "${workspaceRoot}"
"osx": {
"filePath": "${file}"
"windows": {
"port": 9000,
"host": "localhost"
and then I tried to run that select the existing PID. That should work
but so far for me no luck.
Message 5 of 8
TRIALCAD2014
I do not recall a consistent scenario. It usually happens when I switch
back between the VS debug and Fusion interface while some code is still
executing.
I think VS thinks server is stopped when the Fusion server becomes
unresponsive. At that point SV abandons showing the disconnect double
link in the menu.
Message 6 of 8
j.han97
I see. I don't think my experience can relate to your matter unfortunately.
Have you tried re-attaching from Fusion 360? Since you mentioned that you can run the script in F360, I assume that it is alive (responding). I would try debugging the script (click Edit instead of Run) from F360 again to re-attach them.
Message 7 of 8
TRIALCAD2014
"I would try debugging the script (click Edit instead of Run) from F360 again to re-attach them. "
Well.. the second screen capture shows what you get when you try that.
As I mentioned, I can still
normally run the script from Fusion .
Thank you for trying to look into it 🙂
Message 8 of 8
j.han97
I have never met this situation before... Seems like I have not spent enough time working with Fusion 360 (fortunately)
