Solution for e57 and rcp uploader and viewer on my own website
I am an IT consultant. We have a customer, who wants us to build them a web-platform that supports the following features:
  1. Upload files
    1. nwd
    2. nwc
    3. e57
    4. rcp
  2. View these files in viewer on the web.
Can you please suggest a suitable product which could help me support all the above mentioned formats and help build this site. I am using Autodesk Forge for nwd and nwc files. But I still need a viewer for the e57 and ecp files that I can embed in my site.
The requirement is to allow users to upload the drawings and point cloud files and then view them on a viewer.
Can you please direct me to a relevant documentation for such APIs and scripts.
Also please suggest a licensing structure for the same.
I have been advised that it's okay if we cannot embed e57 files.
But we do need a viewer for rcp and supporting rcs files for our own website that we can customise.
Please advise.
Thanks in anticipation
imajar
Hi @Anonymous ,
I'm not sure if you realized this, but your post is in the fusion 360 forum, which is an Autodesk product aimed at a completely different clientele than the file formats you mentioned in your post . . . But here is some information that may help get you pointed in the right direction:
The NWD and NWC formats are Autodesk Navisworks files - Sounds like you have those figured out.
The other two formats could be problematic.  They are point cloud files related to Autodesk Recap, RCP is a recap project file and the E57 is a generic point cloud file that Recap can import. More information available here, with "reality solutions SDK group" here.
As a big FYI:  Recap files can be massive and contain alot of data!  The last 4 recap projects I did were 4.7 GB, 19.9 GB, 16.7 GB,  and 13 GB respectively.
I dont know if Recap has any kind of online viewer.  If it doesnt, then a different avenue you could investigate is that RCP files can be inserted into Navisworks (NWD) files. . .
Hope this helps.  Good Luck.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Hello @imajar ,
Thanks for pointing me in the correct direction. The reason I posted here was that the name suggested "360" and I was hoping if of all the products in market, this could help me process rcp/rcs files.
But again, your explanation was par sufficient and would really help me chalk out a plan for integration.
Cheers,
Y
You can try use the Autodesk Forge API. I am using the same on my website.
https://forge.autodesk.com/en/docs/viewer/v2/developers_guide/overview/h
https//forge.autodesk.com/en/docs/model-derivative/v2/developers_guide/supported-translations/
Hope that helps.
Greets Fabi
@Anonymous , I am already using Autodesk Forge APIs for Navisworks files.
Can you confirm if the same APIs work for rcs files?
Thanks a ton!
Cheers,
Yogesh
