skript failed: the relative resourcefolder path not found
Dear Autodesk Support,
when I try to run any skript added to fusion 360, the program says "skript failed: the relative resourcefolder path not found".
What is the relative resourcefolder path and how can I fix this porblem?
Thanks and best
Marc
BrianEkins
That's typically the error for an add-in when it's defining a command or inputs in a dialog and it's referencing a folder where the images for the command icon or for the command input are located.  Could it be that there is a missing folder with what you have?
Brian Ekins
