SketchDimension Does Not Work
tperam
Message 1 of 22
tperam
    SketchDimension in the following C++ Sample Program: Programming Interface Sample Programs Modeling Sketches Create sketch lines in various ways,
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-98e163be-fd07-11e4-9c39-3417ebd3d5be
does not work.
I copied the whole program in the sample.
Please help.
Thurai
Ptr<SketchDimensions> sketchDimensions = sketch->sketchDimensions();
if(!sketchDimensions)
return false;
Ptr<SketchDimension> sketchDimension = sketchDimensions->addDistanceDimension(recLines->item(0)->startSketchPoint(), recLines->item(0)->endSketchPoint(), HorizontalDimensionOrientation, Point3D::create(5.5, -1, 0));
if(!sketchDimension)
return false;
Accepted solutions (3)
Replies (21)
Message 21 of 22
BrianEkins
I think we misunderstood where you were seeing the problem.  The default behavior is that sketch dimensions are only displayed when the sketch is being edited.  You can override this by using the "Show Dimension" switch for the sketch. In the API you can control this switch by using the Sketch.areDimensionsShown property and set it to True.
Brian Ekins
Message 22 of 22
tperam
Thanks Brian.
Thurai
