SketchCopy Add-In Sample
zhijie.li
Alumni Alumni
zhijie.li
There used to be some posts in forum saying that they wish to copy a sketch from one document to another. However it doesn’t support the feature in current Fusion. So I did some investigation and created an add-in “SketchCopy” via Fusion API in JavaScript which can support cross document copying for sketch. Hopefully this can help the users who have such needs. And it can be also considered as a demo to show what Fusion API can do with sketch.
You can download “SketchCopy.zip” in attachments and refer to video “HowTo.swf” to see how to use it.
Besides, the add-in doesn’t support conic curve and elliptical arch for now. If you met any issue, please let me know.
Zhijie
zhijie.li
For how to use it, please find the video in url https://youtu.be/TX-3yG6TKsw
Thanks for the script. Very handy for much needed function.
will.dameron
Has anyone been using this Add-In?
I installed it, and I appear to be able to copy a sketch no problem. But, when I go to paste in a new drawing it doesn't work and gives me the error: "command executed failed: Environment is not supported"
As near as I can tell my workflow is the same as the how to video. I create a sketch, use the app to copy the sketch, go into a new project, use the paste feature of the script, click on the component, and select OK. Any one else have this issue?
Will
Hey, been having issues similar to the poster above. When attempting to paste from one design to another, I get the error "command executed failed: InternalValidationError : rMatrix- >target ObjectPath(objectPath)"
