Show "Properties" & "Edit Feature" Dialog Boxes Using Python
isocam
isocam
Can anybody help?
Is it possible, using a Python script, to show the "Properties" & "Edit Feature" dialog boxes?
Many thanks in advance!
Darren
kandennti
Hi @isocam .
This will bring up the RootComponent properties dialog.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        sels: adsk.core.Selections =  ui.activeSelections
        sels.clear()
        sels.add(root)
        app.executeTextCommand(u'Commands.Start FusionPropertiesCommand')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
However, it is not stable when tried here.
We will also show the edit dialog for the first extrusion of the RootComponent.
def run(context):
    try:
        for feat in root.features:
            feat.objectType
        extrudeFeat = getExtrudeFeature(root)
        if not extrudeFeat:
            return
        sels.clear()
        sels.add(extrudeFeat)
        app.executeTextCommand(u'Commands.Start FusionExtrudeEditCommand')
    except:
        if ui:
def getExtrudeFeature(comp) -> adsk.fusion.ExtrudeFeature:
    extrudeFeat = None
    for feat in comp.features:
        if feat.objectType == 'adsk::fusion::ExtrudeFeature':
            extrudeFeat = feat
            break
    return extrudeFeat
