setSelectionLimits
setSelectionLimits
brad.bylls
setSelectionLimits
brad.bylls
I have a add-in script that used to work a few months ago. (I have not used it since then)
The script creates a dialog box for selection input.
I have set both _inputSelectTargets and _inputSelectTools to allow multiple selections. setSelectionLimits(0)
However, each one now only allows for 1 selection.
# Create the command dialog
_inputSelectTargets = inputs.addSelectionInput('target', 'Target Bodies', 'Select the Bodies\nThat Will Be Cut')
_inputSelectTargets.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
_inputSelectTargets.setSelectionLimits(0)
_inputSelectTools = inputs.addSelectionInput('tool', 'Tool Bodies', 'Select the Bodies\nThat Will Do The Cutting')
_inputSelectTools.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
_inputSelectTools.setSelectionLimits(0)
_inputHideTools = inputs.addBoolValueInput('hideTools', 'Keep Tool Bodies?', True)
_inputErrMessage = inputs.addTextBoxCommandInput('errMessage', '', '', 2, True)
_inputErrMessage.isFullWidth = True
Brad Bylls
kandennti
BrianEkins
This appears to be fixed in the latest update.
Brian Ekins
brad.bylls
Brian,
My version is 2.0.14113 and it is not fixed.
I don't know if this is the latest version, if it is not, how do I get it?
Brad
Brad Bylls
kandennti
@brad.bylls .
The latest is V2.0.14337.
Under normal circumstances, if Fusion360 is running, LiveUpdate will function and update the software.
I have not used it, but if it does not work, the Service Utility may be able to fix it successfully.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Ove...
brad.bylls
@kandennti
Thank you.
That worked.
Now the setSelectionLimits works properly.
Brad
Brad Bylls
