SetAsCylindricalJointMotion: RuntiError 3: Cannot be editied before rolling back
I'm using the following code to define a cylindrical motion between a bolt and a screw driver model which are aligned on the Y Axis, I get the error:
Runtime Error 3: Cannot be Edited before Rolling Back
This happens when  the line : "toolPath.setAsCylindricalJointMotion(direction)" is called.
what is causing this error and how can I make the code work?
def makeToolPath(self,jointGeometry, motionType, direction=None, rotationAxis =None, yaw=None,customDirection=None, customRotation=None, customYaw=None, object1=None, object2=None ):
        if object1 is None:
            object1=self.toolComponent
        if object2 is None:
            object2=self.objectComponent
        joints =self.objectInstance.asBuiltJoints
        occ1 = self.objectInstance.allOccurrencesByComponent(object1)[0]
        occ2 = self.objectInstance.allOccurrencesByComponent(object2)[0]
        toolPathInput = joints.createInput(occ1, occ2, jointGeometry)
        toolPath = joints.add(toolPathInput)
        if motionType == adsk.fusion.JointTypes.RigidJointType:
            toolPath.setAsRigidJointMotion()
        elif motionType==adsk.fusion.JointTypes.SliderJointType:
            toolPath.setAsSliderJointMotion(direction,customDirection)
        elif motionType==adsk.fusion.JointTypes.RevoluteJointType:
            toolPath.setAsRevoluteJointMotion(rotationAxis,customRotation)
        elif motionType==adsk.fusion.JointTypes.PlanarJointType:
            toolPath.setAsPlanarJointMotion(direction,customDirection)
        elif motionType==adsk.fusion.JointTypes.CylindricalJointType:
            toolPath.setAsPinSlotJointMotion(rotationAxis, direction, customRotation, customDirection)
        elif motionType==adsk.fusion.JointTypes.BallJointType:
            toolPath.setAsBallJointMotion(direction, yaw,customDirection, customYaw)
        else:
            raise TypeError("There is no motion type of "+motionType)
        return toolPath
jointGeometry = adsk.fusion.JointGeometry.createByPoint(self.toolComponent.originConstructionPoint)
direction = adsk.fusion.JointDirections.YAxisJointDirection
motionType = adsk.fusion.JointTypes.CylindricalJointType
self.setToolPath(jointGeometry, motionType, direction)
liujac
Edit on existing joint, you must roll the timeline back to just before the joint.
But in the case of joint creations, you can change your code as below, then it should work.
        if object1 is None:
        if object2 is None:
            toolPathInput.setAsRigidJointMotion()
            toolPathInput.setAsSliderJointMotion(direction,customDirection)
            toolPathInput.setAsRevoluteJointMotion(rotationAxis,customRotation)
            toolPathInput.setAsPlanarJointMotion(direction,customDirection)
            toolPathInput.setAsCylindricalJointMotion(direction)
            toolPathInput.setAsPinSlotJointMotion(rotationAxis, direction, customRotation, customDirection)
            toolPathInput.setAsBallJointMotion(direction, yaw,customDirection, customYaw)
        else:
        return toolPath
Jack
