set selectionLimits with multiple selectionInputs
m0d0
m0d0
I am not sure if I am misunderstanding the correct use of the SelectionCommandInput.setSeklectionLimits() function.
The code below should create two selection inputs, each needing at least one selected body for being a valid input.
So I thought the ok-button will turn only clickable only if both selection inputs certify this condition (like an AND statement), but it seems like the OK-button turns clickable if a single input changes to a valid selection and is turned unclickable at the moment a  single selection gets invalid.
Is this the intended behaviour? In this case, I guess, I need to use a ValidateInputsEvent, right?
Or is there something wrong with my code?
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
_handlers = []
_app = adsk.core.Application.get()
_ui = _app.userInterface
_cmdPanel = 'SolidScriptsAddinsPanel'
_cmdId = 'AVeryUniqueCmdId'
def run(context):
    design = adsk.fusion.Design.cast(_app.activeProduct)
    commandDefinitions = _ui.commandDefinitions
    cmdDef = commandDefinitions.itemById(_cmdId)
    if not cmdDef:
        cmdDef = commandDefinitions.addButtonDefinition(_cmdId,'Test Cmd','tooltip',"")
    onCommandCreated = TestCommandCreatedHandler()
    cmdDef.commandCreated.add(onCommandCreated)
    _handlers.append(onCommandCreated)
    _ui.allToolbarPanels.itemById(_cmdPanel).controls.addCommand(cmdDef)
def stop(context):
    try:
        cmdDef = _ui.commandDefinitions.itemById(_cmdId)
        if cmdDef:
            cmdDef.deleteMe()
        buttonControl = _ui.allToolbarPanels.itemById(_cmdPanel).controls.itemById(_cmdId)
        if buttonControl:
            buttonControl.deleteMe()
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class TestCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            _ui.messageBox('command execution')
        except:
            if _ui:
class TestCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            onExecute = TestCommandExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            inputs = cmd.commandInputs
            selInput = inputs.addSelectionInput('id1','name','promp')
            selInput.addSelectionFilter('Bodies')
            selInput.setSelectionLimits(1,0)
            selInput2 = inputs.addSelectionInput('id2','name2','promp')
            selInput2.addSelectionFilter('Bodies')
            selInput2.setSelectionLimits(1,0)
        except:
            if _ui:
I would appreciate any ideas.
Thanks, m0dd0
  • API
nnikbin
Hi @m0d0
It seems to be a bug. I have reported it here in 2016.
