Set limit on inputvalues
theartezt
theartezt
I'm looking for a solution where I can limit the input range of values. My goal is to rule out negative numbers and numbers higher than a set limit. For example: input is valid when between 10 and 100. Let's say someone tries 1000, it's not valid and an errormessage is displayed.
My ideas of doing this:
In the CommandValidateInputsHandler, but I can test on (e.g.) toplimit but not the lower limit at the same time.
Second idea: this must be done in the creation of the input as a isValidExpression.
What I've tried, but not seems to be working..
# Event handler for the validateInputs event.
class SampleCommandValidateInputsHandler(adsk.core.ValidateInputsEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            app = adsk.core.Application.get()
            ui  = app.userInterface
            eventArgs = adsk.core.ValidateInputsEventArgs.cast(args)
            inputs = eventArgs.firingEvent.sender.commandInputs
            # Verify .
            scaleInput = inputs.itemById('scale')
            if 10 < scaleInput.value < 100 :
                eventArgs.areInputsValid = True
            else:
                scaleInput = inputs.itemById('value')
                else:
                    eventArgs.areInputsValid = False
        except:
            if ui:
                ui.messageBox('Failed ValidateInputsHandler:\n{}'.format(traceback.format_exc()))
Could you point me in the right direction?
MichaelT_123
Hi Mr. TheArterzt,
Consider :
class SampleCommandChangedInputsHandler(adsk.core.InputChangedEventHandler):
bla, bla bla,...
            if scaleInput.value < 10 :
                scaleInput.value = 10
bla, bla bla
Regards
MichaelT
MichaelT
