Selection Errors when Copying Objects
I've had a reoccuring issue related to selection filters and copying bodies during an execution preview process. I've isolated the problem to the code below. If you run this code and select a plane, a cylinder will be created on that plane, then it will be copied to a new component. This copy will then cause the selectionCommandInput in the command to select the body, not the original plane. I can't understand why this is being selected but it causes an input change and in a large system causes many bugs. It also changes the body color which is undesirable. Can someone explain how to avoid this or correct the bug in the API?
Here is the sample code, and an image of the problem. Note that the selectionCommand has filters for planes but clearly the body is selected. When I start this command I just select one of the origin planes and watch the preview execute, once the copy is completed the body is "magically" selected.
import adsk.core, adsk.fusion, traceback
app = None
ui  = None
design = None
handlers = []
commandId = 'selectionDebugCommand'
commandName = commandId
commandDescription = commandName
selected = None
def getSelection(commandInput):
    entity = commandInput.selection(0).entity
    ui.messageBox(entity.classType())
    if entity.classType() == adsk.fusion.Profile.classType():
        plane = entity.plane
    else:
        if entity.classType() == adsk.fusion.BRepBody.classType():
            return
        plane = entity.geometry
    global selected
    selected = entity
class ApplyAppearanceInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            ui.messageBox("change")
            cmd = args.firingEvent.sender
            inputs = cmd.commandInputs
            global commandId
            for inputI in inputs:
                    getSelection(inputI)
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def createNewComponent(rootComp):
    allOccs = rootComp.occurrences
    newOcc = allOccs.addNewComponent(adsk.core.Matrix3D.create())
    return newOcc.component
class ApplyAppearanceExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            if selected == None:
                ui.messageBox("Nothing")
                return
            global design
            global selected
            root = design.rootComponent
            sketches = root.sketches
            ui.messageBox(selected.classType())
            sketch = sketches.add(selected)
            sketch.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), 10)
            extrudes = root.features.extrudeFeatures
            prof = sketch.profiles[0]
            extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
            distance = adsk.core.ValueInput.createByReal(-5)
            extInput.setDistanceExtent(False, distance)
            extrudes.add(extInput)
            comp1=createNewComponent(root)
            occurencesOfCopy = root.allOccurrencesByComponent(comp1)
            occ =occurencesOfCopy.item(0)
#        collection = adsk.core.ObjectCollection.create()
            for body in root.bRepBodies:
                body.copyToComponent(occ)
#            collection.add(body)
        except:
            if ui:
class ApplyAppearanceCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            cmd.isRepeatable = False
            onExecute = ApplyAppearanceExecuteHandler()
            cmd.execute.add(onExecute)
            cmd.executePreview.add(onExecute)
            onInputChanged = ApplyAppearanceInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            # keep the handler referenced beyond this function
            handlers.append(onExecute)
            handlers.append(onInputChanged)
            global commandId
            selectionInput = inputs.addSelectionInput(commandId + '_selection', 'Select', 'Select plane')
            selectionInput.addSelectionFilter('PlanarFaces')
            selectionInput.addSelectionFilter('ConstructionPlanes')
            selectionInput.addSelectionFilter('Profiles')
        except:
            if ui:
def run(context):
    try:
        global app
        app = adsk.core.Application.get()
        global ui
        ui = app.userInterface
        global design
        design = adsk.fusion.Design.cast(app.activeProduct)
        global commandId
        global commandName
        global commandDescription
        cmdDef = ui.commandDefinitions.itemById(commandId)
        if not cmdDef:
            cmdDef = ui.commandDefinitions.addButtonDefinition(commandId, commandName, commandDescription) # no resource folder is specified, the default one will be used
        onCommandCreated = ApplyAppearanceCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        handlers.append(onCommandCreated)
        inputs = adsk.core.NamedValues.create()
        cmdDef.execute(inputs)
        # prevent this module from being terminate when the script returns, because we are waiting for event handlers to fire
        adsk.autoTerminate(False)
    except:
        if ui:
Here is a bad solution to the problem. At the end of execute preview I can check that selectionCommandInputs are only holding items that they can use, comparing them to their filters as in the code below. However this only allows me to clear the selection filters if there is a failure which is bad UI design because it removes user input. Is there a better solution?
#Author-Autodesk Inc.
#Description-Apply an appearance to selected faces, bodies or occurrences.
app = None
ui  = None
design = None
handlers = []
commandInput = None
selected = None
def getSelection():
    global commandInput
    ui.messageBox("Seaking selection")
        ui.messageBox("Selected Body")
        commandInput.clearSelection()
        return
    global selected
    selected = entity
    ui.messageBox("retrieved Selection")
    def __init__(self):
        super().__init__()
        try:
            getSelection()
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
                return
            global design
            global selected
            getSelection()
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            global commandId
            global commandInput
            commandInput = selectionInput
        except:
            if ui:
def run(context):
    try:
        global app
        global ui
        global design
        global commandId
        global commandName
        if not cmdDef:
    except:
        if ui:
marshaltu
Thank you for reporting issue to us. I can reproduce the issue and narrow it down to the bug of body.copyToComponent(). We logged UP-28927 in our internal system to track the issue. We will investigate and fix in future releases.
Unfortunately I have no better workaround for you.
Marshal
Marshal Tu
Fusion Developer
