Scripts not Running
Scripts not Running
krimmought
Scripts not Running
krimmought
Howdy.
Right now only one of the gear generators that I have downloaded is functional.  Additionally the SpurGear script does nothing, though it can be stopped.  Just shows a small semi-circle of green.  Some of the other scripts still function.  The one functional add-in can be is the only one that loads into my toolbar.
Could anyone suggest a reason or a fix for any of this?
Thank yous!
thomasa88
It's hard to say what's happening, but I would start by unchecking Run on startup on all add-ins, restart fusion and enable them one by one.
If a change in Fusion is causing trouble, you might be able to get an error message from the console:
1. Open the text console (ctrl+alt+c) (its somewhere in the view menu as well.)
2. Switch it to "Py".
3. Write  1   and press enter (you should be able to write anything, really)
4. The terminal should now spit out any "kept" add-in errors (or close enough)
