- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently I'm having to create a lot of Cam setups manually for each component in my assembly. The worst part of this for me is naming the set ups correctly, because I want the set-up to be named specifically as the component name. I've meticulously named the components in the model space. Is it possible to write a script/add that pulls the name of the part into the name of the setup? Its not a problem to confirm the other options in setup dialogue box, because I need to align the orientation axis manually anyway, but to have the name fill out automatically would be so helpful.
I was hoping either I select the component, then run the add in, or I click an add in button and then click on a component? Or is there a better way?
Is this possible, and where do I start?
Interestingly, I've noticed that when you start a set up manually, you can right click on the list of components, and add it to the "model", and also the x axix and the y axis etc, but I can't find a way to name it in the same method, so I thought maybe a script could do it?
I'll also put a right click "add name to set up" request on the ideas stations, but its not exactly the most exciting of requests, so likely will get few votes.
Thanks everyone.
