save design & "add version description" pop up
Message 1 of 18
I have a code wich opens designs, modifies them, saves them and closes them.
This code turns successfully for months, but since yesterday, when the line  :
app.activeDocument.save(' ')
comes then the pop up windows "add version description" appears but I don't want it because I have now to click "ok" for each documents and wait each of those pop up...
Is there a solution to fix it please?
Replies (17)
Message 2 of 18
ahsan.autodesk
Thanks for reporting this. This appears to be a regression. I've logged an internal issue (UP-45932) to track this. Someone will look into it shortly.
Regards
Ahsan Ali
Fusion Senior Software Architect
Message 3 of 18
goyals
I just tried on build 2.0.7824 but not able to reproduce it. I tried following steps
1. Open an existing design from side-panel
2. Modify the design.
3. Open text command window and switch to "Py" mode
4. Execute below script
app = adsk.core.Application.get()
app.activeDocument.save("")
A new version is created without showing "Add Version Description" dialog. Not sure If I am missing any step here. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
Message 4 of 18
I am sorry I check more precisely and I make a mistake. This is not the save function but the saveas function which has my problem.
But I don't understand , this code works :
dossier=projet.rootFolder.dataFolders.itemByName('api')
dossier=dossier.dataFolders.itemByName('pieces_standards')
dossier=dossier.dataFolders.itemByName('inox_nouveau')
dossier=dossier.dataFolders.itemByName('UNICUM_embalage_moteur')
fichier=dossier.dataFiles.item(0)
#OUVERTURE FICHIER LONGI ext
i=0
while fichier.name!='moteur_entier':
      fichier=dossier.dataFiles.item(i)
      i=i+1
# Get active design
product = app.documents.open(fichier,True)
design = adsk.fusion.Design.cast(product)
# Get active design
product = app.activeProduct
rootComp = design.rootComponent
#if app.activeDocument.isSaved:
app.activeDocument.save('')
app.activeDocument.saveAs('_moteur_entier',dossier2,fichier.name,fichier.name)
app.activeDocument.close(True)
AND this code makes me the popp up :
i=0
while fichier.name!='LS-xxxx':
    i=i+1
# Get active design
# Get active design
rootComp = design.allParameters
#On modifie la longueur du longreron secondaire
dimension=rootComp.itemByName('d9') #d9 = longueur d'extrusion
dimension.value=long_sec/10
#On sauvegarde ce nouveau longeron dans le bon dossier
ui.messageBox('0')
ui.messageBox('1')
app.activeDocument.saveAs('LS-'+str(int(long_sec)),dossier2,'LS-xxxx','LS-xxxx')
#POP UP WINDOW !!!!!!!!
ui.messageBox('2')
app.activeDocument.save('LS-xxxx')
ui.messageBox('3')
So i am quite lost 🙄.
Do i make something wrong?
Message 5 of 18
goyals
I am not able to notice any problem with SaveAs method as well. I hope you must have added following line in second case intentionally which displays a message box . Can you please attach screenshot of the dialog you are noticing? Thanks.
ui.messageBox('1')
Shyam Goyal
Message 6 of 18
yes i write
ui.messagebox('1')
ui.messagebox('2')
ui.messagebox('3')
to know where the problem arrives exactly (a kind of debug).
 so I had the message 1 which appears and just after the add version description pop up and just after the message 2 and 3.
Message 7 of 18
With this code for exemple :
product = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
app.activeDocument.saveAs('_secondaires_longueur',dossier2,'_secondaires_longueur','_secondaires_longueur')
app.activeDocument.saveAs('_secondaires_total',dossier2,'_secondaires_total','_secondaires_total')
app.activeDocument.saveAs('_primaires_longueur',dossier2,'_primaires_longueur','_primaires_longueur')
app.activeDocument.saveAs('_primaire_transversal',dossier2,'_primaire_transversal','_primaire_transversal')
app.activeDocument.saveAs(dossier_client,dossier2,dossier_client,dossier_client)
I need to click 5 times "ok" on the dialogbox "add version description":
Message 8 of 18
goyals
I am able to reproduce this problem now. I appreciate you effort for following up on it. UP-45932 is the ticket number created to track this. Thanks for your patience.
Shyam Goyal
Message 9 of 18
Havve you some news about it ?
Message 10 of 18
goyals
We are able to fix it. The fix would be available as part of next major update of Fusion. This update is plan at the end of June. Thanks.
Shyam Goyal
Message 11 of 18
scottmoyse
API regressions being fixed this slowly isn't good. It certainly doesn't bode well for anyone trying to seriously build add-ins on top of Fusion 360 which are either business critical or being sold to customers.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 12 of 18
keqingsong
This is getting fixed in the upcoming update.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 13 of 18
goyals
@Anonymous May I know if you get the chance to try the fix came through latest Fusion update. Let us know If you notice any issue. Thanks.
Shyam Goyal
Message 14 of 18
@keqingsong Can you let me know when the fix will be released please? Thank you
Message 15 of 18
goyals
The fix is already provided with Fusion June update. Are you still seeing this issue even after update? Thanks.
Shyam Goyal
Message 16 of 18
@Anonymous actually it works now when you enter at least one string in the description. I was trying without any strings and the pop up window was still appearing. Thanks for following up.
Message 17 of 18
I will try as soon as possible (I think this week or next week)
I didn't have time last weeks.
Message 18 of 18
Ok i have just tried and it seems to work generally.
This code works (without pop up):
app.activeDocument.saveAs("LS-"+str(int(long_sec)),dossier2,"LS-xxxx","LS-xxxx")
But with this code I have the pop up
app.activeDocument.saveAs('MUR-PISCINE',dossier2,'','')
app.activeDocument.save('MUR-PISCINE')
For me it is ok now.
Thank you to have fixed it !
