RuntimeError: 5 : API Function not yet implemented
Hi, I am getting a "RuntimeError: 5 : API Function not yet implemented" on the python line
if triangleMesh.hasTexture:
I also get this error on triangleMesh.textureCoordinates
Are these properties not yet implemented, or am I calling them incorrectly?
neil.liu
Thanks for reporting the issue. We are trying to make Fusion APIs better. APIs are still under development, these two APIs you mentioned are not implemented yet. We will implement them in the future.
Thanks Neil
Is there some other way to get texture coordinates?  I found some old sample code using neu_modeling, and did some querying using dir(), and it appears to have some geometry functions that would give this - neu_modeling.get_body_triangles() for instance.  Is there any documentation on the neu_* python modules?  Can the neu_* and adsk.* modules be iter-mixed (ie. call neu_modeling.get_body_triangles() with the body from Component.bRepBodies.item()?
KrisKaplan
No.  At this time there isn't any other way to get these texture coordinates from the API.
Please avoid adding any dependency on the neu_* modules.  That was part of an incomplete legacy API that we are no longer supporting, and that will be removed once a few remaining dependencies are migrated to the new API.
Kris
Kris Kaplan
Thank you for the quick and detailed answer on this.  Solution accepted.
