Run Python script on "New Component"
isocam
isocam
Can anybody help?
Is is possible to run a Python script when creating a "New Component" in Fusion 360?
Many thanks in advance!!!
Darren
kandennti
@Hi @isocam .
If it is an add-in rather than a script, it is possible to monitor that the command to create the component is executed.
Try this by creating a new add-in.
#FusionAPI_python addin
import adsk.core, adsk.fusion, traceback
handlers = []
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        onCommandTerminated = MyCommandTerminatedHandler()
        ui.commandTerminated.add(onCommandTerminated)
        handlers.append(onCommandTerminated)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        ui.messageBox('Stop addin')
    except:
        if ui:
# Event handler for the commandTerminated event.
class MyCommandTerminatedHandler(adsk.core.ApplicationCommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        ui = None
        try:
            eventArgs = adsk.core.ApplicationCommandEventArgs.cast(args)
            newCompCmds =[
                'FusionCreateNewComponentCommand',
                'FusionCreateNewCompCmdFromBody']
            if eventArgs.commandId in newCompCmds:
                # Add the process you want to perform
                ui.messageBox('Catch New Component')
        except:
            if ui:
PinRudolf
 - woops, Kandennti beat me to it -
