Revolutioin link mechanism
ChaosComb
Advisor Advisor
ChaosComb
#Refer this site:https://forums.autodesk.com/t5/fusion-360-api-and-scripts/inverse-kinematics-robot/m-p/5901869#M944
import adsk,math,traceback
def driveJoint():
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        # Get the two occurrences in the root.  These are two
        # instances of the same component.
        door1 = root.occurrences.itemByName('Demo v3:1')
        #door2 = root.occurrences.itemByName('door v3:2')
        # Get the component referenced by the occurrences.
        doorComp = door1.component
        # Get the joint in the piston component.  It will be in
        # the context of the piston component.
        motorJoint = doorComp.joints.itemByName('Rev1')
        # Create proxies of the joint for each occurrence.
        motor1 = motorJoint.createForAssemblyContext(door1)
        #motor2 = motorJoint.createForAssemblyContext(door2)
        # Get the RevoluteJointMotion object from each joint.
        revJointMotion1 = motor1.jointMotion
        #revJointMotion2 = motor2.jointMotion
        # Drive the joints.
        for i in range(-90, 90, 3):
            revJointMotion1.rotationValue = i * (math.pi/180.0)
            #revJointMotion2.rotationValue = (i+180) * (math.pi/180.0)
            adsk.doEvents()
        for i in range(90, -90, -3):
            adsk.doEvents()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def main():
    print ('drive')
    driveJoint()
main()
Hi, I try to revolute the link mechanism by using Fusion360 Python API.
I successd revolution Joints.
(I referred this URL:
However, one joints only rotates, doesnt move as link mechanism.
Please watch this video.
ChaosComb
