Replicating ChainSelection
joshM57CN
joshM57CN
I am trying to find a way to select a series of connected edges (tangent and nontangent) similar to how edges are selected in Manufacturing. Pick one and the whole loop is selected.
So far, I've been able to get tangent edges by setting my selection filter to "Edges" and in my PreSelectHandler using: eventArgs->additionalEntities(edge->tangentiallyConnectedEdges());
Is there a similar, or effective way to do this other than picking them one by one? Utlimately, I'm planning on passing the collection of edges into a Path to do other things with down the road.
kandennti
Hi @joshM57CN -San.
The following sample selects the edge of a face that shares the selected edge.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Edge'
        selFilter: str = 'Edges'
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        edge: fusion.BRepEdge = sel.entity
        sels: core.Selections = ui.activeSelections
        for idx, face in enumerate(edge.faces):
            sels.clear()
            edges: fusion.BRepEdges = face.edges
            [sels.add(e) for e in edges]
            ui.messageBox(f"BRepFace.Edges Index:{idx} Count:{edges.count}")
        # for idx, coEdge in enumerate(edge.coEdges):
        #     sels.clear()
        #     edges: fusion.BRepEdges = coEdge.loop.edges
        #     [sels.add(e) for e in edges]
        #     ui.messageBox(f"BRepCoEdge.Loop.Edges Index:{idx} Count:{edges.count}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def select_ent(
    msg: str,
    filter: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filter)
        return sel
    except:
        return None
Normally, for a solid edge, you would see two MessageBoxes in a loop because the two faces share the edge.
joshM57CN
Oh that's very helpful actually! I think coedges and choosing the right index was the piece I was missing.
As a follow up, is there away to do something similar within a SelectionCommandInput handler?
Thanks Again!
kandennti
@joshM57CN -San.
I used CustomGraphics to display the desired Edges.
import traceback
import adsk
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
_edgeIpt: core.SelectionCommandInput = None
_idxIpt: core.BoolValueCommandInput = None
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onPreview = MyPreviewHandler()
            cmd.executePreview.add(onPreview)
            _handlers.append(onPreview)
            global _edgeIpt
            _edgeIpt = inputs.addSelectionInput(
                "_edgeIptId",
                "Edge",
                "Select Edge",
            _edgeIpt.addSelectionFilter("Edges")
            global _idxIpt
            _idxIpt = inputs.addBoolValueInput(
                "_idxIptId",
                "Other Side",
                True,
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyPreviewHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        global _edgeIpt
        edge: fusion.BRepEdge = _edgeIpt.selection(0).entity
        global _idxIpt
        idx = 0 if _idxIpt.value else -1
        edges: fusion.BRepEdges = edge.faces[idx].edges
        draw_cg_edges(edges)
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
def draw_cg_edges(edges: fusion.BRepEdges) -> None:
    blue = fusion.CustomGraphicsSolidColorEffect.create(
        core.Color.create(
            0, 0, 255, 255
    des: fusion.Design = app.activeProduct
    root: fusion.Component = des.rootComponent
    cgGroup: fusion.CustomGraphicsGroup = root.customGraphicsGroups.add()
    cgGroup.depthPriority = 1
    edge: fusion.BRepEdge = None
    for edge in edges:
        cgCrv: fusion.CustomGraphicsCurve = cgGroup.addCurve(
            edge.geometry
        cgCrv.color = blue
        cgCrv.weight = 2
joshM57CN
That's fantastic. Thank you so much!
