"Invalid Splitting Tool" while trying to use splitBodyFeatures.add with a Profile
FusionMaxR
FusionMaxR
I am trying to split a Body with a Profile or a Sketch as a Splitting tool while using the api, but I alway get an error, that the splittingTool I use is not valid. How can I split a Body with the api while using a more complex geometry than a single sketchline?
The Reference Manual gives some contradicting information about what can be used as an splittingTool:
SplitBodyFeatureInput Object --> "The splitting tool is a single entity that can be either a solid or open BRepBody,construction plane, profile, or a face."
SplitBodyFeature.setSplittingTool Method --> The splitting tool is a single entity that can be either a solid body, open body, construction plane, face, or sketch curve that partially or fully intersects the body to split.
Here is my Test-Code and a picture of my Test-Model:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design: adsk.fusion.Design = app.activeProduct
        rootComp = design.rootComponent
        body = ui.selectEntity('Select a body', 'Bodies').entity
        splittingTool: adsk.fusion.Profile = ui.selectEntity('Select a face to split the body.','Profiles').entity
        isExtended = True
        splitBodyFeatures = rootComp.features.splitBodyFeatures
        input = splitBodyFeatures.createInput(body, splittingTool, isExtended)
        splitBodyFeature = splitBodyFeatures.add(input)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @FusionMaxR .
I can reproduce the error, and also, when I set the splittingTool to surfaceBody, it did not cause the error.
I think it is a bug.
However, I think I can create an alternative.
john.kirchner
This is a bug, a profile should be a valid input for splittingTool - I will create a ticket for this to be fixed. In the meantime splittingTool should work with a ConstructionPlane, BRepBody, SketchCurve, or BRepFace.
kandennti
@FusionMaxR .
I have thought of an alternative, but it is incomplete because it is an error in direct mode.
# Fusion360API Python script
import traceback
import adsk.core
import adsk.fusion
def run(context):
    ui = None
    try:
        body: adsk.fusion.BRepBody = rootComp.bRepBodies[0]
        splittingTool: adsk.fusion.Profile = rootComp.sketches[0].profiles[0]
        exec_splitBody_by_profile_like(body, splittingTool)
    except:
        if ui:
def exec_splitBody_by_profile_like(
    body: adsk.fusion.BRepBody,
    prof: adsk.fusion.Profile,
) -> None:
    def get_min_max_length(
        vector: adsk.core.Vector3D,
        sktPlane: adsk.core.Plane,
    ) -> list[float, float]:
        measMgr: adsk.core.MeasureManager = app.measureManager
        bBox: adsk.core.OrientedBoundingBox3D = measMgr.getOrientedBoundingBox(
            body,
            vector,
            get_perpendicular_vector(vector),
        offset = bBox.length * 0.5
        bBoxPoints = []
        for l in [offset, -offset]:
            vec: adsk.core.Vector3D = vector.copy()
            vec.scaleBy(l)
            pnt: adsk.core.Point3D = bBox.centerPoint.copy()
            pnt.translateBy(vec)
            bBoxPoints.append(pnt)
        infLine: adsk.core.InfiniteLine3D = adsk.core.InfiniteLine3D.create(
            bBox.centerPoint,
            vector,
        origin: adsk.core.Point3D = sktPlane.intersectWithLine(infLine)
        lengths = []
        for p in bBoxPoints:
            dist = origin.distanceTo(p)
            vec = origin.vectorTo(p)
            vec.normalize()
            if vector.isEqualTo(vec):
                dist *= -1
            lengths.append(dist)
        return lengths
    def get_perpendicular_vector(
    ) -> adsk.core.Vector3D:
        v: adsk.core.Vector3D = adsk.core.Vector3D.create(1,0,0)
        if vector.isParallelTo(v):
            v = adsk.core.Vector3D.create(0,1,0)
        return vector.crossProduct(v)
    def create_extrude(
        lengths: list,
    )-> adsk.fusion.ExtrudeFeature:
        comp: adsk.fusion.Component = prof.parentSketch.parentComponent
        extrudeFeats: adsk.fusion.ExtrudeFeatures = comp.features.extrudeFeatures
        extrudeIpt: adsk.fusion.ExtrudeFeatureInput = extrudeFeats.createInput(
            prof,
            adsk.fusion.FeatureOperations.NewBodyFeatureOperation,
        extrudeIpt.setTwoSidesExtent(
            adsk.fusion.DistanceExtentDefinition.create(
                adsk.core.ValueInput.createByReal(lengths[0])
                adsk.core.ValueInput.createByReal(lengths[1])
        extrudeIpt.isSolid = False
        return extrudeFeats.add(extrudeIpt)
    def split_body(
        targetBody: adsk.fusion.BRepBody,
        toolBody: adsk.fusion.BRepBody,
    ) -> adsk.fusion.SplitBodyFeature:
        comp: adsk.fusion.Component = targetBody.parentComponent
        splitBodyFeats: adsk.fusion.SplitBodyFeatures = comp.features.splitBodyFeatures
        splitIpt: adsk.fusion.SplitBodyFeatureInput = splitBodyFeats.createInput(
            targetBody,
            toolBody,
            True,
        return splitBodyFeats.add(splitIpt)
    def remove_body(
    ) -> adsk.fusion.RemoveFeature:
        removeFeats: adsk.fusion.RemoveFeatures = comp.features.removeFeatures
        return removeFeats.add(targetBody)
    app: adsk.core.Application = adsk.core.Application.get()
    des: adsk.fusion.Design = app.activeProduct
    if des.designType == adsk.fusion.DesignTypes.ParametricDesignType:
        tl: adsk.fusion.Timeline = des.timeline
        startPos = tl.markerPosition
    skt: adsk.fusion.Sketch = prof.parentSketch
    minMaxLength = get_min_max_length(
        body,
        skt.xDirection.crossProduct(skt.yDirection),
        skt.referencePlane.geometry
    extrudeFeat: adsk.fusion.ExtrudeFeature = create_extrude(
        prof,
        minMaxLength,
    split_body(
        body,
        extrudeFeat.bodies[0]
    remove_body(extrudeFeat.bodies[0])
    if tl:
        try:
            tl.timelineGroups.add(startPos, tl.markerPosition -1)
        except:
            pass
When I do SplitBody manually, it seems to be responding to the profile loop rather than responding to the profile.
However, the error also occurred in the profile loop.
FusionMaxR
Thank you for your help kandennti and john.kirchner. For now I could change my process to use combines, CutFeatureOperation which works fine. I will keep an eye open for the bug to be fixed and then maybe will change my process back to the intended way.
Regards Max
