Quartz module
Quartz module
brad.bylls
Quartz module
brad.bylls
My add-in imports the 'keyboard' module that works well on my Win machine.
I have the keyboard library in my code library.
I am using it so when the user enters some data in a text box, it 'Tabs' to the next text box and also 'Esc' after a message 'error' box.
However, when loading up on a Mac OS it gives an error about not finding a "Quartz" module which it is looking for in keyboard.py.
All I can find on the internet is to use "pip install pyobjc"
I don't think all users will know how to do this.
Is there something I can put in my code to do this automatically?
Or where can I find the 'Quartz' library to put in my code library like I did with the keyboard library?
Or using something else instead of 'keyboard' that works on both Mac and Win?
Thank you.
Brad Bylls
tykapl.breuil
What you can do is manually pip install pyojbc then in the installation logs you'll get the location of what was installed. Then simply put it in a file in your addin and adding the path to that file in sys.path (with sys.path.insert).
brad.bylls
That does not work for me.
I get error messages:
ERROR: Could not find a version that satisfies the requirement quartz (from versions: 0.0.1.dev0)
ERROR: No matching distribution found for quartz
I tried: pip install quartz
I tried: pip install pyojbc
I tried: pip install pyobc-framework-quartz
They all come up with error messages
Brad Bylls
tykapl.breuil
I have the same problem when trying to install quartz on my machine but that's a quartz problem not a fusion api one.
brad.bylls
So I finally got the Quartz module loaded.
Now Quartz needs AppKit to be imported.
Here is what I get:
$ py -m pip install --user AppKit
Collecting AppKit
  Using cached AppKit-0.2.8.tar.gz (7.6 kB)
Collecting flask
  Using cached Flask-2.0.2-py3-none-any.whl (95 kB)
Collecting pygobject
  Using cached PyGObject-3.42.0.tar.gz (716 kB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Collecting beautifulsoup4
  Using cached beautifulsoup4-4.10.0-py3-none-any.whl (97 kB)
Collecting Werkzeug>=2.0
  Using cached Werkzeug-2.0.2-py3-none-any.whl (288 kB)
Collecting click>=7.1.2
  Using cached click-8.0.3-py3-none-any.whl (97 kB)
Collecting itsdangerous>=2.0
  Using cached itsdangerous-2.0.1-py3-none-any.whl (18 kB)
Collecting Jinja2>=3.0
  Using cached Jinja2-3.0.3-py3-none-any.whl (133 kB)
Collecting pycairo>=1.16.0
  Using cached pycairo-1.20.1-cp37-cp37m-win_amd64.whl (1.2 MB)
Collecting soupsieve>1.2
  Using cached soupsieve-2.3.1-py3-none-any.whl (37 kB)
Requirement already satisfied: colorama; platform_system == "Windows" in c:\users\bradb\appdata\roaming\python\python37\site-packages (from click>=7.1.2->flask->AppKit) (0.4.3)
Collecting importlib-metadata; python_version < "3.8"
  Using cached importlib_metadata-4.10.1-py3-none-any.whl (17 kB)
Collecting MarkupSafe>=2.0
  Using cached MarkupSafe-2.0.1-cp37-cp37m-win_amd64.whl (14 kB)
Collecting zipp>=0.5
  Using cached zipp-3.7.0-py3-none-any.whl (5.3 kB)
Collecting typing-extensions>=3.6.4; python_version < "3.8"
  Using cached typing_extensions-4.0.1-py3-none-any.whl (22 kB)
Using legacy setup.py install for AppKit, since package 'wheel' is not installed.
Building wheels for collected packages: pygobject
  Building wheel for pygobject (PEP 517) ... error
  ERROR: Command errored out with exit status 1:
   command: 'C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\python.exe' 'C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\lib\site-packages\pip\_vendor\pep517\_in_process.py' build_wheel 'C:\Users\bradb\AppData\Local\Temp\tmprb1c1hj9'
       cwd: C:\Users\bradb\AppData\Local\Temp\pip-install-7w3rldvr\pygobject
  Complete output (44 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build\lib.win-amd64-3.7
  creating build\lib.win-amd64-3.7\pygtkcompat
  copying pygtkcompat\generictreemodel.py -> build\lib.win-amd64-3.7\pygtkcompat
  copying pygtkcompat\pygtkcompat.py -> build\lib.win-amd64-3.7\pygtkcompat
  copying pygtkcompat\__init__.py -> build\lib.win-amd64-3.7\pygtkcompat
  creating build\lib.win-amd64-3.7\gi
  copying gi\docstring.py -> build\lib.win-amd64-3.7\gi
  copying gi\importer.py -> build\lib.win-amd64-3.7\gi
  copying gi\module.py -> build\lib.win-amd64-3.7\gi
  copying gi\pygtkcompat.py -> build\lib.win-amd64-3.7\gi
  copying gi\types.py -> build\lib.win-amd64-3.7\gi
  copying gi\_constants.py -> build\lib.win-amd64-3.7\gi
  copying gi\_error.py -> build\lib.win-amd64-3.7\gi
  copying gi\_gtktemplate.py -> build\lib.win-amd64-3.7\gi
  copying gi\_option.py -> build\lib.win-amd64-3.7\gi
  copying gi\_ossighelper.py -> build\lib.win-amd64-3.7\gi
  copying gi\_propertyhelper.py -> build\lib.win-amd64-3.7\gi
  copying gi\_signalhelper.py -> build\lib.win-amd64-3.7\gi
  copying gi\__init__.py -> build\lib.win-amd64-3.7\gi
  creating build\lib.win-amd64-3.7\gi\repository
  copying gi\repository\__init__.py -> build\lib.win-amd64-3.7\gi\repository
  creating build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\Gdk.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\GdkPixbuf.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\GIMarshallingTests.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\Gio.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\GLib.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\GObject.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\Gtk.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\keysyms.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\Pango.py -> build\lib.win-amd64-3.7\gi\overrides
  copying gi\overrides\__init__.py -> build\lib.win-amd64-3.7\gi\overrides
  running build_ext
  creating build\temp.win-amd64-3.7
  creating build\temp.win-amd64-3.7\Release
  creating build\temp.win-amd64-3.7\Release\gi
  "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.29.30133\bin\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -DPY_SSIZE_T_CLEAN -IC:\Users\bradb\AppData\Local\Temp\pip-install-7w3rldvr\pygobject -IC:\Users\bradb\AppData\Local\Temp\pip-install-7w3rldvr\pygobject\gi "-IC:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\include" "-IC:\Program Files (x86)\Microsoft Visual Studio\Shared\Python37_64\Include" "-IC:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.29.30133\include" "-IC:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\include\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.19041.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.19041.0\shared" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.19041.0\um" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.19041.0\winrt" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.19041.0\cppwinrt" /Tcgi\gimodule.c /Fobuild\temp.win-amd64-3.7\Release\gi\gimodule.obj -FImsvc_recommended_pragmas.h
  gimodule.c
  gi\gimodule.c: fatal error C1083: Cannot open include file: 'msvc_recommended_pragmas.h': No such file or directory
  error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2019\\BuildTools\\VC\\Tools\\MSVC\\14.29.30133\\bin\\HostX86\\x64\\cl.exe' failed with exit code 2
  ERROR: Failed building wheel for pygobject
Failed to build pygobject
ERROR: Could not build wheels for pygobject which use PEP 517 and cannot be installed directly
Any help appreciated.
Thank you.
Brad Bylls
tykapl.breuil
Maybe try adding this flag to your command ?
--no-use-pep517
If that doesn't work, as this isn't a Fusion API specific problem, I would advise creating a thread on some more general site (stack overflow maybe ?) where you might get some better help.
brad.bylls
Thanks, but did not work.
I'll try stackflow.
Brad Bylls
