Python Script - Save To Specific Folder
isocam
isocam
Can anybody help?
I have the following Python script file....
import adsk.core, adsk.fusion, traceback
def run(context):
ui = adsk.core.UserInterface.cast(None)
try:
app :adsk.fusion.Application = adsk.core.Application.get()
ui = app.userInterface
# get active document
doc :adsk.core.Document = app.activeDocument
# get data folder
dataProject :adsk.core.DataProject = app.data.dataProjects[0]
rootFolder :adsk.core.DataFolder = dataProject.rootFolder
# exec saveAs
doc.saveAs('hoge', rootFolder, '', '')
msg = f'You have saved the active document to\n'
msg += f' project "{dataProject.name}" with the name "{doc.name}".'
ui.messageBox(msg)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Please see the attached picture.
Then you run the script it saves a file called 'hoge' to the "Assets" LIBRARIES (Ringed In Blue).
Does anybody know how  to modify the script so that it saves a file called "hoge" to any of the folders in the
"Project Files" directory, for example "1040 - Darrens Test Folder" or "2000 - Cromar Platform - OLD" etc etc
Many thanks in advance!
Darren
BrianEkins
Your problem is where you're getting the project to save into. You're getting the first project in the collection, which apparently happens to be the "Asset Libraries" folder. You either need to find the project based on the name or you can use the line below to use the project that is currently active in the data panel.
dataProject: adsk.core.DataProject = app.data.activeProject
Brian Ekins
