Python Script - Open Specific File In Folder
isocam
isocam
Can anybody help?
If I have a folder, In "PROJECT FILES" called "TEST FOLDER" and a document, inside the "TEST FOLDER" called "TEST PART".
How, using a Python script, do I open the document called "TEST PART"?
Many thanks in advance!
Darren
kandennti
Hi @isocam -San.
We have created a simple sample script.
For a simple sample, we are not looking for deep folders.
Also, Fusion360's data panel allows files with the same name to be created in the same folder. Therefore, there is a possibility that the desired file cannot be opened.
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        projectName = "PROJECT FILES"
        folderName = "TEST FOLDER"
        fileName = "TEST PART"
        # Project
        proj: core.DataProject = None
        for x in app.data.dataProjects.asArray():
            if x.name == projectName:
                proj = x
                break
        if not proj:
            ui.messageBox('No Project')
            return
        # Folder
        folder: core.DataFolder = None
        for x in proj.rootFolder.dataFolders.asArray():
            if x.name == folderName:
                folder = x
                break
        if not folder:
            ui.messageBox('No Folder')
            return
        # File
        file: core.DataFile = None
        for x in folder.dataFiles.asArray():
            if x.name == fileName:
                file = x
                break
        if not file:
            ui.messageBox('No File')
            return
        # Open
        app.documents.open(file, True)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I have uploaded here the add-in you asked about in your private message.
https://github.com/kantoku-code/Fusion360_OpenDocumentType-Sample
