Python: How to create a Panel / CommanButton in the Solid Tab
lichtzeichenanlage
Advisor Advisor
lichtzeichenanlage
Not sure if I'm using the right terminology but this is what I want to do:
This is what I'm doing right now:
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        # create panel
        workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
        toolbarPanels = workSpace.toolbarPanels
        # get toolbarPanel
        toolbarPanel = toolbarPanels.itemById(UI_TOOLBAR_PANEL_ID)
        if not toolbarPanel:
            toolbarPanel = toolbarPanels.add(UI_TOOLBAR_PANEL_ID, UI_TOOLBAR_PANEL_NAME, 'SelectPanel', False)
        # create command definition
        commanDefinition = ui.commandDefinitions.itemById(UI_EXPORT_DESIGN_COMMAND_ID)
        if not commanDefinition:
            commanDefinition = ui.commandDefinitions.addButtonDefinition(UI_EXPORT_DESIGN_COMMAND_ID, UI_EXPORT_DESIGN_NAME, UI_EXPORT_DESIGN_TOOLTIP, 'resources/exportIt_designs_icons')
        # Adds the commandDefinition to the toolbar panel
        cmdControl = toolbarPanel.controls.addCommand(commanDefinition)
        cmdControl.isPromotedByDefault = True
        # add event handler
        onCommandCreated = ExportDesignCommandCreatedHandler()
        commanDefinition.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
    except:
        logger.error(traceback.format_exc())
Any hint what's wrong in my code?
kandennti
Hi @lichtzeichenanlage .
I think it is better to use toolsTab.toolbarPanels instead of workSpace.toolbarPanels.
        # create panel
        # workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
        # toolbarPanels = workSpace.toolbarPanels
        # get toolbarPanels
        allDesignTabs = ui.toolbarTabsByProductType('DesignProductType')
        toolsTab = allDesignTabs.itemById('SolidTab')
        toolbarPanels = toolsTab.toolbarPanels
        # get toolbarPanel
lichtzeichenanlage
I thought I've tried this. Thanks for the solution.
