Python cannot import Adsk.core module
Hello guys. Sorry I didn't find a solution
I cannot run even simple test script. Here is screenshot:9a0597d4607a19298fa57743e19583a3
When I choose Edit in Scripts it doesnt run Visual Studio .Just nothing happends
kandennti
Hi @Anonymous .
Is it VSCode launched from Fusion360?
I feel that the file path of python.exe is different.
Here will be helpful.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-743C88FB-CA3F-44B0-B0B9-FCC378D0D782
Currently, “ms-python.python” is recommended for Ver2019.9.34911. Don't forget.
An easy way to avoid the "ModuleNotFoundError: No module named 'adsk'" error is to add the path to sys.path.
1)Copy the value of "python.autoComplete.extraPaths" in the .vscode \ settings.json file.
2)Add the path before import adsk.core ~ .
import sys
sys.path.append (<Copied python.autoComplete.extraPaths value>)
Ok I'll try that method.
Vscode was open manually because after clicking button Edit in Fusion 360 nothing happends
