python api rectangular pattern get warning: Reference Failures, Failed to get owner occurrence transform
mr.liu0518
Observer Observer
mr.liu0518
Observer
Observer
I am trying to make a script for fusion360 to generate scaffolding(some tubes pattern with component structure); But when the final step(rectangular pattern) is done I got the warning: Reference Failures, Failed to get owner occurrence transform; I also create a simple test script trying to identify the problem, and I find that the issues only happened when the activeComponent is not the rootComponent. I need some advice to figure out the problem and avoid this.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        # get the active component of the design
        activeComp = design.activeComponent
        # create a new sub component
        subOccs = activeComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        subComp = subOccs.component
        subComp.name = "subComp"
        # draw a circle in the new component
        sketches = subComp.sketches
        xyPlane = subComp.xYConstructionPlane
        sketche = sketches.add(xyPlane)
        sketche.sketchCurves.sketchCircles.addByCenterRadius(
            adsk.core.Point3D.create(0, 0, 0), 1
        profile = sketche.profiles.item(0)
        # create an extrusion
        extInput = subComp.features.extrudeFeatures.createInput(
            profile, adsk.fusion.FeatureOperations.NewBodyFeatureOperation
        distance = adsk.core.ValueInput.createByReal(1)
        extInput.setDistanceExtent(False, distance)
        subComp.features.extrudeFeatures.add(extInput)
        # retangle pattern the sub component
        inputEntities = adsk.core.ObjectCollection.create()
        inputEntities.add(subOccs)
        quantityOne = adsk.core.ValueInput.createByReal(2)
        quantityTwo = adsk.core.ValueInput.createByReal(2)
        distanceOne = adsk.core.ValueInput.createByReal(2)
        distanceTwo = adsk.core.ValueInput.createByReal(2)
        rectangPatternFeats = subComp.features.rectangularPatternFeatures
        rectangPatternFeatInput = rectangPatternFeats.createInput(
            inputEntities,
            subComp.zConstructionAxis,
            quantityOne,
            distanceOne,
            adsk.fusion.PatternDistanceType.SpacingPatternDistanceType,
        rectangPatternFeatInput.setDirectionTwo(
            subComp.xConstructionAxis, quantityTwo, distanceTwo
        rectangPatternFeats.add(rectangPatternFeatInput)
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
Jorge_Jaramillo
I believe your problem is in line #43:
Shouldn't you use a different component to built the feature input other than the one you want to replicate with the pattern?  ActiveComp.features.rectangularPatternFeatures should be used instead?
I couldn't test it right now, because I'm outside of the office.  Maybe later I can give a try.
Jorge Jaramillo
Software Engineer
Jorge_Jaramillo
Hi @mr.liu0518 ,
I was able to make it run without warnings having root or another component active.
The problem was to reference items of the component (z and x construction axes) that is being replicated, and the lack of using the occurrence proxy if the target component is not the root component.
This is the code with some remarks with the changes:
def run(context):
    ui = None
    try:
        activeOccu = design.activeOccurrence # <== added
        if activeOccu:  # <== if added
            inputEntities.add(subOccs.createForAssemblyContext(activeOccu)) # <== use occurrence proxy if not from root
        else:
        # rectangPatternFeats = subComp.features.rectangularPatternFeatures
        rectangPatternFeats = activeComp.features.rectangularPatternFeatures  # <== replace previous line
            inputEntities,
            # subComp.zConstructionAxis,
            activeComp.zConstructionAxis, # <== replace previous line
            quantityOne,
            distanceOne,
            # subComp.xConstructionAxis, quantityTwo, distanceTwo
            activeComp.xConstructionAxis, quantityTwo, distanceTwo # <== replace previous line
    except:
        app.log("Failed:\n{}".format(traceback.format_exc()))
Jorge Jaramillo
Software Engineer
mr.liu0518
Observer
Observer
Yes, the rectangular pattern should apply to the parent component instead of the one I want to replicate with the pattern. I tried your code and it works properly, but I still have no idea when to use the occurrence proxy. I try the approach below and it still gets the warning when the active component is not the root component.
def run(context):
    ui = None
    try:
        # get the active component and create sub component
        subOccu = activeComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        subComp = subOccu.component
        # create a sub_sub_component inside the previous created sub_component
        sub_subOccu = subComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        # sub_subComp = sub_subOccu.component
        # rectangularPatterns
        inputEntities.add(sub_subOccu.createForAssemblyContext(subOccu))
        quantityOne = adsk.core.ValueInput.createByReal(4)
        distanceOne = adsk.core.ValueInput.createByReal(40)
        rectangularPatterns = subComp.features.rectangularPatternFeatures
        rectangularPatternInput = rectangularPatterns.createInput(
            inputEntities,
            quantityOne,
            distanceOne,
        rectangularPatterns.add(rectangularPatternInput)
    except:
        if ui:
