Python API Offset statement of 0.12 cm leaves dimension of 0.00 in drawing.
Condition:
Fusion 360 Build 20.5278
Windows 10, Startup License
Model file with a simple profile (location: https://a360.co/2LkT4NJ )
Attached python script.
Run Python Script.
Expect the first sketch profile to be selected to which an offset (with a reference point) is created .12 cm (1.2 mm) to the outside of the profile. The reference point is assumed to be outside the profile (within the context of this usage).
Observation:
After running the script, the sketch was edited. There was a dimension applied to the offset which had a value of 0.00. The offset was measured at 1.2 mm with the Measure tool.
Comments:
My normal unit preferences are in mm.
#Author-mwinrock
#Description-Locates first sketch profile in root compenet and attempts to create an offset.
import adsk.core, adsk.fusion, adsk.cam, traceback
bUpdateFusion=True
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # at this point in time, the user must load the sketch profile.
        #doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        sketch = rootComp.sketches.item(0)
        prof_1 = sketch.profiles.item(0)
        # create offset from profile
        line = sketch.sketchCurves.item(0)
        curves = sketch.findConnectedCurves(line)
        # Create the offset.
        dirPoint = adsk.core.Point3D.create(1000, 1000, 1000)
        offsetCurves = sketch.offset(curves, dirPoint, 0.12)
        prof_2 = sketch.profiles.item(1)
        if bUpdateFusion:
            # Call doEvents to give Fusion 360 a chance to react.
            adsk.doEvents()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I had a similar problem (C++ code) - but I was too lazy to report itSmiley Frustrated
Might be a bug in the API.
And it's not just sketch-dimension cosmetic. As far as I can remember a "Compute All" took the 0 (zero) value and the resulting geometry no longer had an offset.
PinRudolf
I encountered the same issue in version 2.0.6045. My current solution is to change the placed dimension to the correct value.
goyals
Thanks you for posting it, We will investigate it further.
Shyam Goyal
Sr. Software Dev. Manager
goyals
We fixed this issue and it would be part of Fusion December release. Thanks.
Shyam Goyal
sougata.mukherjee
Hi ,
We have fixed this issue , the fix has been targeted for December release.
