PyQt5 with fusion 360 possible ?
s143233T69WR
Message 1 of 1
s143233T69WR
Ive been trying to get PyQt5 to work as a python add-in, but nothing seems to work.
running it on the main thread crashes fusion 360, and running it on a seperate thread also crashes it.
this is what im trying right now, but starting to realise it might not be possible to hold a thread for a gui myself without fusion 360 getting mad, am i doing something wrong ?
# Assuming you have not changed the general structure of the template no modification is needed in this file.
from . import commands
from .lib import fusion360utils as futil
import logging
import random
import sys
import time
from PyQt5.QtCore import QRunnable, Qt, QThreadPool
from PyQt5.QtWidgets import (
    QApplication,
    QLabel,
    QMainWindow,
    QPushButton,
    QVBoxLayout,
    QWidget,
logging.basicConfig(format="%(message)s", level=logging.INFO)
# 1. Subclass QRunnable
class Runnable(QRunnable😞
    def __init__(self, n😞
        super().__init__()
        self.n = n
    def run(self😞
        # Your long-running task goes here ...
        for i in range(5😞
            logging.info(f"Working in thread {self.n}, step {i + 1}/5")
            time.sleep(random.randint(700, 2500) / 1000)
class Window(QMainWindow😞
    def __init__(self, parent=None😞
        super().__init__(parent)
        self.setupUi()
    def setupUi(self😞
        self.setWindowTitle("QThreadPool + QRunnable")
        self.resize(250, 150)
        self.centralWidget = QWidget()
        self.setCentralWidget(self.centralWidget)
        # Create and connect widgets
        self.label = QLabel("Hello, World!")
        self.label.setAlignment(Qt.AlignHCenter | Qt.AlignVCenter)
        countBtn = QPushButton("Click me!")
        countBtn.clicked.connect(self.runTasks)
        # Set the layout
        layout = QVBoxLayout()
        layout.addWidget(self.label)
        layout.addWidget(countBtn)
        self.centralWidget.setLayout(layout)
    def runTasks(self😞
        threadCount = QThreadPool.globalInstance().maxThreadCount()
        self.label.setText(f"Running {threadCount} Threads")
        pool = QThreadPool.globalInstance()
        for i in range(threadCount😞
            # 2. Instantiate the subclass of QRunnable
            runnable = Runnable(i)
            # 3. Call start()
            pool.start(runnable)
def run(context😞
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        commands.start()
        app = QApplication(sys.argv)
        window = Window()
        window.show()
        sys.exit(app.exec())
    except:
        futil.handle_error('run')
def stop(context😞
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
Replies (0)
