Proxy from UserInterface.selectEntity?
CADacombs
CADacombs
The script below allows the selection of a BrepBody using UserInterface.selectEntity.  It then duplicates the body to the root component.  The new body is at the component definition's position and orientation.  Shouldn't it instead be coincident with the proxy?
import adsk.core as ac
import adsk.fusion as af
import traceback
app: ac.Application = ac.Application.get()
ui: ac.UserInterface = app.userInterface
design: af.Design = app.activeProduct
rootComp = design.rootComponent
def addBody_toRoot(body: af.BRepBody):
    bodies: af.BRepBodies = rootComp.bRepBodies
    if design.designType == af.DesignTypes.ParametricDesignType:
        baseFeat = rootComp.features.baseFeatures.add()
        baseFeat.startEdit()
        bodies.add(body, baseFeat)
        baseFeat.finishEdit()
    else:
        # DirectDesignType.
        bodies.add(body)
def run(context):
    try:
        while True:
            try:
                sel = ui.selectEntity('Select body', 'Bodies')
            except:
                break
            body: af.BRepBody = sel.entity
            if body.assemblyContext is None:
                app.log("Native object picked.  Try again.")
                continue
            addBody_toRoot(body)
    except:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
    app.log("End of script.")
kandennti
Hi @CADacombs .
I think this is a specification.
An easy way to perform that operation is to use the TemporaryBRepManager.copy method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-26E53439-9DE5-4A11-93AD-7E0570BAA657
    tmpMgr: af.TemporaryBRepManager = af.TemporaryBRepManager.get()
    clone: af.BRepBody = tmpMgr.copy(body)
        bodies.add(clone, baseFeat)
    else:
        # DirectDesignType.
        bodies.add(clone)
The copy method always returns the result on the RootComponent.
