Project a body on a sketch
TRIALCAD2014
TRIALCAD2014
Hi, It's possible from the UI to project a body onto a sketch when in a sketch via the create/project however I don't find any reference about how to do that in the API.
Any example beyond https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7a1981fc-0daa-4fc3-808f-ebccc5fa816e
which does not actually seem to support projecting a body.
Thank you,
Adrian
kandennti
Hi @TRIALCAD2014 .
I prepared a body of some kind and ran the following script, and it projected without any problems.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        targetBody: adsk.fusion.BRepBody = root.bRepBodies[0]
        skt: adsk.fusion.Sketch = root.sketches.add(
            root.xYConstructionPlane
        skt.project(targetBody)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It is possible that I am misunderstanding something.
If there is a problem, please be more specific.
TRIALCAD2014
Hi, thank you very much. I also managed to get it running. Initially I
was getting an internal error -with no info about the cause. Also the
docs don't explicitly mention body as an argument.
I still don't know why I was getting the error but it might have been
because the sketch and body might have been in different components.
All this is jumping through hoops because of inconsistency and severe
limitations in the product.
