Problems using tmpMgr.booleanOperation()
maurizio_manzi
Message 1 of 9
maurizio_manzi
To create an OrientedBoundingBox3D from multiple faces, I merge them using the script below.
See the attached script as file and as text.
Most of the time this works very well, but with more complex (many) faces I get an error message.
If I manually stitch the faces together, it works without any issues (see video).
Does anyone have an idea how to successfully combine the faces for the OrientedBoundingBox3D?
Best regards
Maurizio
import traceback
import adsk.core
import adsk.fusion
# import adsk.cam
# Initialize the global variables for the Application and UserInterface objects.
app = adsk.core.Application.get()
ui  = app.userInterface
def run(_context: str):
    """This function is called by Fusion when the script is run."""
    try:
        faces = []
        for i in range(ui.activeSelections.count):
            sel = ui.activeSelections.item(i)
            if isinstance(sel.entity, adsk.fusion.BRepFace):
                faces.append(sel.entity)
        if len(faces) > 0:
            create_union_body(faces)
    except:
        app.log(f'Failed:\n{traceback.format_exc()}')
# Create a temporary UnionBody
def create_union_body(faces: list) -> adsk.fusion.BRepBody:
    if len(faces) < 1:
        return None
    tmpMgr: adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
    tmpBody: adsk.fusion.BRepBody = tmpMgr.copy(faces[0])
    if len(faces) < 2:
        return tmpBody
    for face in faces[1:]:
            tmpBody,
            tmpMgr.copy(face),
            adsk.fusion.BooleanTypes.UnionBooleanType,
    return tmpBody
Replies (8)
Message 2 of 9
maurizio_manzi
the cad file and the script
Message 3 of 9
kandennti
Hi @maurizio_manzi -san.
For this data, the offsetting without TemporaryBRepManager did not produce any errors and was fast enough to process.
import traceback
import adsk.core
import adsk.fusion
    try:
        faces = []
        if len(faces) > 0:
            create_clone_bodies(faces)
            print("Done")
    except:
# Create Clone Body - zero offset
def create_clone_bodies(faces: list) -> list[adsk.fusion.BRepBody]:
    if len(faces) < 1:
        return None
    comp: adsk.fusion.Component = faces[0].body.parentComponent
    offsetFeats: adsk.fusion.OffsetFeatures = comp.features.offsetFeatures
    offsetIpt: adsk.fusion.OffsetFeatureInput = offsetFeats.createInput(
        adsk.core.ObjectCollection.createWithArray(faces),
        adsk.core.ValueInput.createByReal(0),
        adsk.fusion.FeatureOperations.NewBodyFeatureOperation,
        False,
    offsetFeat: adsk.fusion.OffsetFeature = offsetFeats.add(offsetIpt)
    return list(offsetFeat.bodies)
Message 4 of 9
maurizio_manzi
thank you.
I need the result for using in:
orientedBBox: core.OrientedBoundingBox3D = measMgr.getOrientedBoundingBox(face, vecLength,vecWidth,).
My first problem is, I have more faces and getOrientedBoundingBox need a single face.
And I think, I can't use the list(offsetFeat.bodies) for this?
Best regards
Maurizio
Message 5 of 9
kandennti
We can do create_union_body after offset.
I don't know what causes the error with booleanOperation, but I think it is less likely to be an error for surfaces that are far apart.
import traceback
import adsk.core
import adsk.fusion
    try:
        faces = []
        if len(faces) > 0:
            bodies = create_clone_bodies(faces)
            resBody: adsk.fusion.BRepBody = create_union_body(bodies)
            des: adsk.fusion.Design = app.activeProduct
            root: adsk.fusion.Component = des.rootComponent
            root.bRepBodies.add(resBody)
            [b.deleteMe() for b in bodies]
            print("Done")
    except:
    if len(faces) < 1:
        return None
        False,
    if len(faces) < 1:
        return None
    if len(faces) < 2:
        return tmpBody
        try:
                tmpBody,
                tmpMgr.copy(face),
        except:
            print("Union error")
    return tmpBody
Message 6 of 9
maurizio_manzi
thank you very much.
It works, but only if document is not parametric.
best regards
Maurizio
Message 8 of 9
maurizio_manzi
Thank you very much
Message 9 of 9
maurizio_manzi
I try to check if it's parametric and then create a BaseFeature (adjusted run function),
but now it will delete all my bodies in root.
Best regards
Maurizio
import adsk.core, adsk.fusion, adsk.cam, traceback, os, math, subprocess, configparser, re
import adsk.core as core
from typing import Tuple
import platform, getpass, webbrowser
    try:
        faces = []
        if len(faces) > 0:
            bodies = create_clone_bodies(faces) # Create copy of faces with 0 offset, because Fusion sometime causes an error at stitching the original faces
            resBody: adsk.fusion.BRepBody = create_union_body(bodies) # Stitch the faces copys as a resBody
            # Optional: Add a base feature if parametric
            baseFeat: fusion.BaseFeature = None
            if des.designType == adsk.fusion.DesignTypes.ParametricDesignType:
                baseFeat = root.features.baseFeatures.add()
            if baseFeat:
                baseFeat.startEdit()
                try:
                    root.bRepBodies.add(resBody, baseFeat) # Add resBody to root
                except:
                    pass
                finally:
                    baseFeat.finishEdit()
            else:
                root.bRepBodies.add(resBody) # Add resBody to root
            ui.messageBox("done")
    except:
    if len(faces) < 1:
        return None
        False,
    if len(faces) < 1:
        return None
    if len(faces) < 2:
        return tmpBody
        try:
                tmpBody,
                tmpMgr.copy(face),
        except:
    return tmpBody
