Problems converting an STL to Brep - More than 10k faces warning
urel.vitorR2KNY
urel.vitorR2KNY
I'm writing code to convert a STL to Brep with the ORGANIC method of the CONVERT MESH command.
When I do the operation manually, Fusion 360 pops up a warning that the body has more than 10k faces, but it manages to perform the operation anyway.
But when I do the same thing via script, it gives an error and I can't do the conversion or finish the code.
Below is a picture of my code and one of the error that appears.
Thanks a lot for the help.
kandennti
Hi @urel.vitorR2KNY .
In order to deal with this problem, I created a script that converts to BRep after dividing one mesh body until it becomes 10000 or less.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/is-it-possible-to-use-text-command-within-...
