Problem with moveFeatures
brad.bylls
brad.bylls
I am trying to move bodies in a script.
I copied the code from the online samples to this:
And got this error but what does it mean?
Brad Bylls
BrianEkins
My guess is that either the features collection or the bodies are not in the same context. I can't tell from your code because the code that shows where you got those are not displayed. I tried a simple case where I deliberately had bodies in two different components and provided both bodies in the context of the component that owned them. In that case, I got the clearer error shown below, so yours is something different. When I provide the correct context, the move was successful.
 Failed:
Traceback (most recent call last):
  File "C:/Users/t_ekinb/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Samples/Samples.py", line 548, in createMove
    move = moves.add(input)
  File "C:\Users/t_ekinb/AppData/Local/Autodesk/webdeploy/develop/6154ed41f984a6d55387f8e7e8a12643fced376b/Api/Python/packages\adsk\fusion.py", line 27058, in add
    return _fusion.MoveFeatures_add(self, input)
RuntimeError: 3 : object is not in the assembly context of this component
Brian Ekins
MichaelT_123
Hi Mr BradBylls,
Consider to add assembly contexts for your bodies ...
body_proxy = body.createForAssemblyContext( bodies_occ )
Regards
MichaelT
MichaelT
brad.bylls
@BrianEkins they are both bRepBodies and are both in the same component.
I tried commenting out line 466 but still didn't work with just one body.
I also tried commenting out line 467 with no luck.
Full code attached.
I will try the assembly suggestion from @MichaelT_123
Thank you
Brad Bylls
brad.bylls
@MichaelT_123  thank you. That worked.
Brad Bylls
