I have attached some code below that will create a pattern feature of a selected component. That part works fine. Problem is, without terminating the code, I want to pull the bounding box of the occurrence that holds the pattern feature. You will see when running the code that the bounding box for that occurrence returns all zeros. If I allow the macro to finish and subsequently re-run just the code on the bottom ("getOccurrencesByCompName") to get the bounding box of the occurrence I get an accurate bounding box:
#DEACTIVATE THE PATTERN FEATURE CODE AND RUN THIS TO SEE THAT IT DOES RETURN THE BOUNDNING BOX BUT ONLY WORKS AFTER THE PATTERN CODE TERMINATES
occ = getOccurrencesByCompName('Main_Rect_Pattern_Z')
bbMin = occ[0].boundingBox.minPoint
bbMax = occ[0].boundingBox.maxPoint
print(bbMin.x,bbMin.y,bbMin.z)
print(bbMax.x,bbMax.y,bbMax.z)
I do not want to terminate the code and have to re-run this other code to gain access to the bounding box information. I need it while the original code is still running.
Looking for a work around for this problem. Is there a way to re-calculate the fusion model so I can pull the bounding box measurements while the code is still running? The bounding box must reflect the pattern feature in the component.
Here is the full code for the pattern feature. You just need a model with a component in it to select. Sample model attached as well.
Eric
import adsk.core, adsk.fusion, traceback
def addExistingComponent(newComp,destComp):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
des: adsk.fusion.Design = app.activeProduct
root = des.rootComponent
occ = destComp.occurrences.addExistingComponent(newComp, adsk.core.Matrix3D.create())
return occ
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def rectangularPattern(srcComp,quantity1,distance1,quantity2,distance2,compName,zDir = False):
""" creates a rectangular pattern feature for a selected component.
pass in the selected occurrence and quantity1,distance1,quantity2,distance2 all
as strings"""
def traverseForBodies(occs,lst):
"""gets all bodies in occurence, including bodies in childOccurences
lst = list()
traverseForBodies(product,lst)"""
if not occs.bRepBodies.count == 0:
for bod in occs.bRepBodies:
if bod.isVisible:lst.append(bod)
try:
#check child occurences
if occs.childOccurrences:
occChild = occs.childOccurrences
for child in occChild:
traverseForBodies(child,lst)
except:
pass
def PatternBodies( srcComp: adsk.fusion.Component,
destOccu: adsk.fusion.Occurrence,
quantityOne: adsk.core.ValueInput,
distanceOne: adsk.core.ValueInput,
quantityTwo: adsk.core.ValueInput,
distanceTwo: adsk.core.ValueInput):
try:
#time the calculation
import timeit
start = timeit.default_timer()
# Create input entities for rectangular pattern
inputEntites = adsk.core.ObjectCollection.create()
# lst = list()
# traverseForBodies(srcComp,lst)
# for i in lst:
# # copy bodies to dest component
# cpb = destOccu.component.features.copyPasteBodies.add(i)
# inputEntites.add(cpb.bodies[0])
#this will pattern the source component within the destination occurrence (destOccu)
#add and occurrence of the source component within the destination occurence
if srcComp.objectType == 'adsk::fusion::Occurrence':
copyComp = destOccu.component.occurrences.addExistingComponent(srcComp.component,adsk.core.Matrix3D.create())
elif srcComp.objectType == 'adsk::fusion::Component':
copyComp = destOccu.component.occurrences.addExistingComponent(srcComp,adsk.core.Matrix3D.create())
#add copyComp to inputEntities to pattern
inputEntites.add(copyComp)
# Get x and y axes for rectangular pattern
xAxis = destOccu.component.xConstructionAxis
yAxis = destOccu.component.yConstructionAxis
zAxis = destOccu.component.zConstructionAxis
# Create the input for rectangular pattern
rectangularPatterns = destOccu.component.features.rectangularPatternFeatures
# Set the data for first direction
if quantity1 != '1' and zDir == False:
rectangularPatternInput = rectangularPatterns.createInput(inputEntites, xAxis, quantityOne, distanceOne, adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
# Set the data for second direction
if quantity2 != '1' and zDir == False:
rectangularPatternInput.setDirectionTwo(yAxis, quantityTwo, distanceTwo)
if zDir == True:
rectangularPatternInput = rectangularPatterns.createInput(inputEntites, zAxis, quantityOne, distanceOne, adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
#DirectionTwo must be set to 1 and distance of 0.00
# Create the rectangular pattern
rectangularFeature = rectangularPatterns.add(rectangularPatternInput)
stop = timeit.default_timer()
print('Pattern Time: ', stop - start)
except:
app.log(f'Error in PatternBodies: {traceback.format_exc()}')
try:
product = app.activeProduct
des = adsk.fusion.Design.cast(product)
desType = des.designType
if desType == 0:
des.designType = adsk.fusion.DesignTypes.ParametricDesignType
#source component to take bodies from
rootComp = adsk.fusion.Design.cast(app.activeProduct).rootComponent
#create the new component
matrix = adsk.core.Matrix3D.create()
destOccu = rootComp.occurrences.addNewComponent(matrix)
destComp = destOccu.component
destComp.name = compName
# create ValueInput's for each dimension quantity1,distance1,quantity2,distance2
quantityOne = adsk.core.ValueInput.createByString(quantity1)
distanceOne = adsk.core.ValueInput.createByString(distance1 + ' cm')
quantityTwo = adsk.core.ValueInput.createByString(quantity2)
distanceTwo = adsk.core.ValueInput.createByString(distance2 + ' cm')
PatternBodies(srcComp, destOccu, quantityOne, distanceOne, quantityTwo, distanceTwo)
return srcComp, destComp
except:
app.log(f'Error in rectangularPattern: {traceback.format_exc()}')
def getOccurrencesByCompName(compName):
"""this function will get the component occurrences name.
Pass in component name from tree and the occurrence will
be returned as newC
ret = getOccurrencesByCompName('XY_Bearing')"""
design = app.activeProduct
root = design.rootComponent
occ = root.occurrences.asList
newC = list()
for i in occ:
if i.component.name == compName:
name = i.fullPathName
newC.append(occ.itemByName(name))
return newC
#RUN THIS FIRST TO CREATE THE PATTERNS, PRINTS ALL ZEROS FOR THE BOUNDING BOX.
#Select body
comp = ui.selectEntity('Select a component', 'Occurrences').entity#.component
print("")
bbMin=comp.boundingBox.minPoint
bbMax=comp.boundingBox.maxPoint
prodL = bbMax.x-bbMin.x
prodW = bbMax.y-bbMin.y
prodH = bbMax.z-bbMin.z
quantityOne=str(4)
distanceOne=str(prodL)
quantityTwo=str(4)
distanceTwo=str(prodW)
ret = rectangularPattern(comp,quantityOne,distanceOne,quantityTwo,distanceTwo,'Main_Rect_Pattern_XY')
#create Z Array
quantityOne=str(5)
distanceOne=str(prodH)
quantityTwo=str(1)
distanceTwo=str(0.00)
ret = rectangularPattern(ret[1],quantityOne,distanceOne,quantityTwo,distanceTwo,'Main_Rect_Pattern_Z',True)
bbMin = ret[1].boundingBox.minPoint
bbMax = ret[1].boundingBox.maxPoint
# #DEACTIVATE THE PATTERN FEATURE CODE AND RUN THIS TO SEE THAT IT DOES RETURN THE BOUNDNING BOX BUT ONLY WORKS AFTER THE PATTERN CODE TERMINATES
# occ = getOccurrencesByCompName('Main_Rect_Pattern_Z')
# bbMin = occ[0].boundingBox.minPoint
# bbMax = occ[0].boundingBox.maxPoint
# print(bbMin.x,bbMin.y,bbMin.z)
# print(bbMax.x,bbMax.y,bbMax.z)
