Print inputs from TableCommandInput into CSV file
tomas.bangoA2EPZ
tomas.bangoA2EPZ
Hello, I'm creating an addin that allows the user to use TableCommandInput to create a table with an arbitrary number of rows and 3 columns to be filled with a value. The table contains 2x BoolValueInput (add/delete) to add or delete a row as the user needs.
I add rows using the function:
import adsk.core
import adsk.fusion
_rowNumber = 0
def addRowTTable(tableInput):
    global _rowNumber
    # Get the CommandInputs object associated with the parent command.
    cmdInputs = adsk.core.CommandInputs.cast(tableInput.commandInputs)
    # Vytvoření com inputs
    NMinp = cmdInputs.addStringValueInput('TableInput_string{}'.format(_rowNumber), 'String', str(0))
    Maxinp =  cmdInputs.addValueInput('TableInput_value{}'.format(_rowNumber), 'Value', 'mm', adsk.core.ValueInput.createByReal(0))
    Mininp =  cmdInputs.addValueInput('TableInput_value{}'.format(_rowNumber), 'Value', 'mm', adsk.core.ValueInput.createByReal(0))
    # Add the inputs to the table.
    row = tableInput.rowCount
    #tableInput.addCommandInput(valueInput, row, 0)
    tableInput.addCommandInput(NMinp, row, 0)
    tableInput.addCommandInput(Mininp, row, 1)
    tableInput.addCommandInput(Maxinp, row, 2)
    # Increment a counter used to make each row unique.
    _rowNumber = _rowNumber + 1
I would like to ask using what method am I able to insert the filled data from the table into a CSV file when I press OK? Since the API for TableCommandInput does not include a ListItems property.
Thank you for any advice
BrianEkins
I think you want to use getInputAtPosition, which allows you to get the input at a specified row and column. You can then get the value from the input and write it out to a CSV file.
Brian Ekins
tomas.bangoA2EPZ
Hello again thank you for the advice I am currently using for and row count to sequentially print "input" from each column on each row. Unfortunately the result pasted into CSV looks like this:
3 collumns and 2 rows:
<adsk.core.ValueCommandInput; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::core::ValueCommandInput > *' at 0x00000171BB2D7630> >,<adsk.core.ValueCommandInput; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::core::ValueCommandInput > *' at 0x00000171BB3BA420> >,
<adsk.core.ValueCommandInput; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::core::ValueCommandInput > *' at 0x00000171BB2D7F90> >,<adsk.core.ValueCommandInput; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::core::ValueCommandInput > *' at 0x00000171BB3BA0F0> >,
How exactly to get the value inside the input? Thank you very much.
BrianEkins
It depends on what you want and the type of input you're using.
For example, if you are using a BoolValueCommandInput, it has a "value" property that returns a Boolean value, so you'll probably want to convert it to a string to save to the CSV. The TextBoxCommandInput has a "text" property that returns a string containing the current value of the text box.
The ValueCommandInput is a bit more complicated. It has both a "value" and an "expression" property. The "expression" property returns what you see in the input. It could be something simple like "2.5 in" or more complex like "Length / 2.0". The "value" property returns the result of evaluating the expression and uses internal database units. For example, the value of the "2.0 in" expression will be a double value of 5.08 since the internal unit for length is Centimeters.
Brian Ekins
tomas.bangoA2EPZ
But how to get from for example  pwatch.getInputAtPosition(i,1) (Where pWatch=inputs.addTableCommandInput('Bay Watch','Tvorba Hlidaných parametru',3,'2:1:1')) to ValueCommandInput.value?
Do I understand correctly that I have created a table using TableCommandInput which has 3 columns and x rows where in 1 column I have StrignValueInput in 2 and 3 I have ValueInput? The function getInputAtPosition returns me the Command Input. By using parentCommand I got one level up but I need one level down to be able to look into ValueInput.value for example. But how to do that?
tomas.bangoA2EPZ
Because I made the function to add a row to the table in a separate file I did not see the properties of the returned object and therefore I was not able to find the .value in the function menu. The getInputAtPosition property is the solution.
