possible adsk.fusion.CombineFeatures.createInput method bug
dirktheeng
dirktheeng
Not sure if this is a bug or just somethign that isn't fully supported yet.  I tried to do a combine and when I follow the docs in spyder it tells me to give it a body and a collection, but then errors out and teslls me it needs 4 entries not 3 (one being self).  Not sure if this is really part of the API yet because CombineFeatures is not in the docs online.  Just checking.
21st Century Woodworking
-Blending 21st Century Woodworking with Old World Skill
marshaltu
I did a quick test in Fusion MAC(1365). It works well. I created two primitives: one box and one cylinder. The two bodies will be combined into one body after running the following scripts.
Please share your codes to us. Then we could find what's root cause?
Marshal
import adsk.core, adsk.fusion, traceback
ui = None
app = None
def main():
global ui, app
try:
app = adsk.core.Application.get()
design = adsk.fusion.Design.cast(app.activeProduct)
comp = design.rootComponent
body1 = comp.bRepBodies.item(0)
body2 = comp.bRepBodies.item(1)
toolBodies = adsk.core.ObjectCollection.create()
toolBodies.add(body2)
input1 = comp.features.combineFeatures.createInput(body1, toolBodies)
comp.features.combineFeatures.add(input1)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
main()
Marshal Tu
Fusion Developer
dirktheeng
let me give this a try and see how it works.  Hopefully I can make it work.
