Message 1 of 1
Poor performance building body using the new BRepBodyDefinition
I've been experimenting with the new BRepBodyDefinition functionality, but I've found its performance to be a bit lacking, especially when compared to stitching together faces with a StitchFeature.
For example, below is a standalone script that creates the helical shape below, first using a BRepBodyDefinition, and then using a Stitch feature.
The version using BRepBodyDefinition takes about 10s to run. While the version using a Stitch feature runs in .2s - 50x faster than the BRepBodyDefinition version.
from adsk.core import Point3D, Vector3D
import adsk.fusion
import time
import traceback
def app():
return adsk.core.Application.get()
def design() -> adsk.fusion.Design:
return adsk.fusion.Design.cast(app().activeProduct)
def root() -> adsk.fusion.Component:
return design().rootComponent
def brep() -> adsk.fusion.TemporaryBRepManager:
return adsk.fusion.TemporaryBRepManager.get()
def create_line_definition(
body_def: adsk.fusion.BRepBodyDefinition,
start_point: adsk.fusion.BRepVertexDefinition,
end_point: adsk.fusion.BRepVertexDefinition):
return body_def.createEdgeDefinitionByCurve(
start_point, end_point,
adsk.core.Line3D.create(start_point.position, end_point.position))
def create_occurrence(*bodies):
new_occurrence = root().occurrences.addNewComponent(adsk.core.Matrix3D.create())
for body in bodies:
new_occurrence.component.bRepBodies.add(body)
return new_occurrence
def collection_of(collection):
object_collection = adsk.core.ObjectCollection.create()
for obj in collection:
object_collection.add(obj)
return object_collection
def create_face_for_planar_lines(wires):
wire_body, _ = brep().createWireFromCurves(wires, allowSelfIntersections=False)
return brep().createFaceFromPlanarWires([wire_body])
def ruled_helical_triangle_via_brep_def(inner_radius: float, outer_radius: float, height: float, pitch: float, turns: float):
body_def = adsk.fusion.BRepBodyDefinition.create()
lump_def = body_def.lumpDefinitions.add()
shell_def = lump_def.shellDefinitions.add()
start_point_defs = [
body_def.createVertexDefinition(
Point3D.create(inner_radius, 0, 0)),
Point3D.create(outer_radius, 0, 0)),
Point3D.create(outer_radius, 0, height))]
helixes = [
brep().createHelixWire(
axisPoint=Point3D.create(0, 0, 0),
axisVector=Vector3D.create(0, 0, 1),
startPoint=point.position,
pitch=pitch,
turns=turns,
taperAngle=0) for point in start_point_defs]
end_point_defs = [body_def.createVertexDefinition(helix.edges[0].endVertex.geometry) for helix in helixes]
helix_edge_defs = [
body_def.createEdgeDefinitionByCurve(start_point_defs[i], end_point_defs[i], helixes[i].edges[0].geometry)
for i in range(3)]
start_edge_defs = [
create_line_definition(body_def, start_point_defs[0], start_point_defs[1]),
create_line_definition(body_def, start_point_defs[1], start_point_defs[2]),
create_line_definition(body_def, start_point_defs[2], start_point_defs[0])
end_edge_defs = [
create_line_definition(body_def, end_point_defs[1], end_point_defs[0]),
create_line_definition(body_def, end_point_defs[2], end_point_defs[1]),
create_line_definition(body_def, end_point_defs[0], end_point_defs[2])
helix_surfaces = [
brep().createRuledSurface(helixes[0].wires[0], helixes[1].wires[0]),
brep().createRuledSurface(helixes[1].wires[0], helixes[2].wires[0]),
brep().createRuledSurface(helixes[2].wires[0], helixes[0].wires[0])
face_def = shell_def.faceDefinitions.add(helix_surfaces[0].faces[0].geometry, isParamReversed=False)
loop_def = face_def.loopDefinitions.add()
loop_def.bRepCoEdgeDefinitions.add(start_edge_defs[0], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[0], False)
loop_def.bRepCoEdgeDefinitions.add(end_edge_defs[0], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[1], True)
face_def = shell_def.faceDefinitions.add(helix_surfaces[1].faces[0].geometry, isParamReversed=False)
loop_def.bRepCoEdgeDefinitions.add(start_edge_defs[1], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[1], False)
loop_def.bRepCoEdgeDefinitions.add(end_edge_defs[1], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[2], True)
face_def = shell_def.faceDefinitions.add(helix_surfaces[2].faces[0].geometry, isParamReversed=False)
loop_def.bRepCoEdgeDefinitions.add(start_edge_defs[2], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[2], False)
loop_def.bRepCoEdgeDefinitions.add(end_edge_defs[2], False)
loop_def.bRepCoEdgeDefinitions.add(helix_edge_defs[0], True)
adsk.core.Plane.create(
Vector3D.create(0, -1, 0)), isParamReversed=False)
body_def.doFullHealing = False
return body_def.createBody()
def ruled_helical_triangle_via_stitching(
start_points = [
Point3D.create(inner_radius, 0, 0),
Point3D.create(outer_radius, 0, 0),
Point3D.create(outer_radius, 0, height)]
helixes = [
startPoint=point,
pitch=pitch,
turns=turns,
taperAngle=0) for point in start_points]
end_points = [helix.edges[0].endVertex.geometry for helix in helixes]
start_lines = [
adsk.core.Line3D.create(start_points[0], start_points[1]),
adsk.core.Line3D.create(start_points[1], start_points[2]),
adsk.core.Line3D.create(start_points[2], start_points[0])
end_lines = [
adsk.core.Line3D.create(end_points[1], end_points[0]),
adsk.core.Line3D.create(end_points[2], end_points[1]),
adsk.core.Line3D.create(end_points[0], end_points[2])
helix_surfaces = [
start_face = create_face_for_planar_lines(start_lines)
end_face = create_face_for_planar_lines(end_lines)
occurrence = create_occurrence(
*helix_surfaces, start_face, end_face)
stitch_input = root().features.stitchFeatures.createInput(
collection_of(occurrence.bRepBodies),
adsk.core.ValueInput.createByReal(app().pointTolerance),
adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
root().features.stitchFeatures.add(stitch_input)
body = brep().copy(occurrence.bRepBodies[0])
occurrence.deleteMe()
return body
def run(_):
try:
new_doc = app().documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
new_doc.activate()
design().designType = adsk.fusion.DesignTypes.DirectDesignType
start_time_ns = time.perf_counter_ns()
root().bRepBodies.add(ruled_helical_triangle_via_brep_def(5, 6, .5, 1, 50))
end_time_ns = time.perf_counter_ns()
print("via brep definition: %f" % ((end_time_ns - start_time_ns) / 1.0e9))
root().bRepBodies.add(ruled_helical_triangle_via_stitching(5, 6, .5, 1, 50))
print("via stitching: %f" % ((end_time_ns - start_time_ns) / 1.0e9))
except:
traceback.print_exc()
