Parts List grouped by Size - working code
info83PHN
info83PHN
Took some brain scratching, and honestly can't say I understand every line of code, but I managed to get a script runnign to export a csv file with a list of all bodies and their sizes, body names, and which Component it's from.
Here's the code if it's of any use to anyone - it's not all my own code - I butchered from multiple places to get to this.
import adsk.core, adsk.fusion, traceback
import csv
import tkinter as tk
from tkinter import filedialog
import time
import os
import os.path
def traverse(occurrences, bodies):
    # recursive method to get all bodies from components and sub-components
    for occ in occurrences:
        for bod in occ.bRepBodies:
            bodies.append(bod)
        if occ.childOccurrences:
            traverse(occ.childOccurrences, bodies)
    return bodies
def run(context):
    global app, ui, product, design, rootComp, features, userParams
    ui = None
    try:
        uSaveThis = 1
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = adsk.core.Application.get().activeProduct
        design = adsk.fusion.Design.cast(product)
        parts = {}
        rootComp = design.rootComponent
        msg = ''
        # Set styles of file dialog.
        fileDlg = ui.createFileDialog()
        fileDlg.isMultiSelectEnabled = True
        fileDlg.title = 'Fusion Open File Dialog'
        fileDlg.filter = '*.*'
        # Show file save dialog
        fileDlg.title = 'Fusion Save File Dialog'
        dlgResult = fileDlg.showSave()
        if dlgResult == adsk.core.DialogResults.DialogOK:
            msg += '\nFile to Save: {}'.format(fileDlg.filename)
        else:
            return
        # Get all Components below root
        occs = rootComp.occurrences
        # add all bodies from all components in the collection
        bodies = []
        bodies = traverse(occs, bodies)
        for body in bodies:
            dimensions = body.boundingBox.minPoint.vectorTo(body.boundingBox.maxPoint).asPoint()
            dimensions = tuple(sorted(dimensions.asArray()))
            if dimensions not in parts:
                parts[dimensions] = dict(quantity=0, names=set(), comp=set())
            parts[dimensions]['quantity'] += 1
            parts[dimensions]['names'].add(body.name)
            parts[dimensions]['comp'].add(body.parentComponent.name)
        fname = format(fileDlg.filename)
        with open(fname, 'w', newline='') as output:
            writer = csv.writer(output)
            writer.writerow(('no', 'quantity', 'd1', 'd2', 'd3', 'bodies', 'component'))
            for i, (dimensions, part) in enumerate(sorted(parts.items())):
                dimensions = tuple(map(lambda d: product.unitsManager.formatInternalValue(d,design.unitsManager.defaultLengthUnits + '^1',False), dimensions))
                writer.writerow((i+1, part['quantity']) + dimensions + (';'.join(part['names']),) + (';'.join(part['comp']),))
        print('Parts list saved to file: {}\r'.format(fname))
        ui.messageBox('CSV File Created')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
info83PHN
OK. so there's 1 issue I can't solve yet.
There are some sizes that appear identical but are listed separate, so I am thinking that there's some weird fraction of a millimeter, like 12.0000000012 that's making it be different.
Anyone ? - in this code, is there a way to trim the dimensions to, say, 3 decimal places ?
Jorge_Jaramillo
You just need to round() each dimension value.  Here it is how I did it:
        N_DECIMALS = 4 # number of decimals of the values in CM's (which is internal unit dimension in Fusion360)
            dimensions = tuple(round(f, N_DECIMALS) for f in sorted(dimensions.asArray()))
Just set N_DECIMALS as you prefer.
Jorge Jaramillo
Software Engineer
info83PHN
@Jorge_Jaramillo  Thank You
I would not have found that in a million years !!
Just an additional note - because the code uses the Boundingbox to get the size, it will only work if the bodies are aligned to the origin planes. Any bodies that are tilted or at an angle, won't report a correct size.
Here's my updated code if anyone wants to experiment :
import csv
import time
import os
import os.path
            bodies.append(bod)
    return bodies
def run(context):
    ui = None
    try:
        uSaveThis = 1
        parts = {}
        msg = ''
        else:
            return
        bodies = []
        for body in bodies:
    except:
        if ui:
