Parallel lines
Parallel lines
brad.bylls
Parallel lines
brad.bylls
Is it possible to tell if two lines in two different sketches on two different planes are parallel?
Brad Bylls
MichaelT_123
Yes, Mr. Brad.Bylls,
 ... cross product of two parallel vectors equals 0
If there is a tolerance involved consider finding an angle between vectors.
Regards
MichaelT
MichaelT
kandennti
@brad.bylls -San.
There are several ways to get Vector3D from SketchLine, and this is one example.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        line1: fusion.SketchLine = root.sketches[0].sketchCurves.sketchLines[0]
        line2: fusion.SketchLine = root.sketches[1].sketchCurves.sketchLines[0]
        vector1: core.Vector3D = line1.geometry.asInfiniteLine().direction
        vector2: core.Vector3D = line2.geometry.asInfiniteLine().direction
        print(f"is Paralle : {vector1.isParallelTo(vector2)}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The Vector3D object has a method to determine parallelism.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-1767ab3d-f6a0-4537-9a8f-90aded44f115
