Pan, orbit, zoom, camera in Fusion 360 api
vareznikovk
vareznikovk
Community Visitor
Community Visitor
I get 6 numbers from a 3D mouse.
(x, y, z, yaw, roll, pitch)
How do I change the camera coordinates in the python fusion 360 api in order to do pan, orbit, zoom operations?
My code addin python code bellow:
import adsk.core, adsk.fusion, traceback, math, time
import os, sys
from . import commands
from .lib import fusion360utils as futil
install\_ = sys.path\[0\] +'\\Python\\python.exe -m pip install pyserial'
os.system('cmd /c "' + install\_ + '"')
import serial
ser = serial.Serial('COM8', 9600)
def move_camera(app, view):
    while(True):
        try:
            camera = view.camera
            target = camera.target  # Use current camera target
            up = adsk.core.Vector3D.create(0, 1, 0)
            data = ser.readline().decode('utf-8').strip().split(' ')
            if len(data) == 6:
                \# x y z yaw pitch roll
                dist = camera.target.distanceTo(camera.eye)
                start_eye = camera.eye
                \# Pan
                new_target = adsk.core.Point3D.create(target.x, target.y, target.z)
                camera.target = new_target
                \# Orbit
                new_eye = adsk.core.Point3D.create(dist \* math.cos((math.pi\*2) \* data\[3\]), dist \* math.sin((math.pi\*2) \* data\[4\]), dist \* math.sin((math.pi\*2) \* data\[5\]))
                camera.eye = new_eye
                #zoom
                zoom_factor = float(data\[0\])
                new_target = adsk.core.Point3D.create(target.x \* zoom_factor, target.y \* zoom_factor, target.z \* zoom_factor)
                camera.upVector = up
                camera.isSmoothTransition = True
                view.camera = camera
            else:
                break
            adsk.doEvents()
            view.refresh()
            time.sleep(0.005)
        except:
            ui = app.userInterface
            if ui:
                ui.messageBox('Failed:\\n{}'.format(traceback.format_exc()))
                stop()
def run(context):
    try:
        \# This will run the start function in each of your commands as defined in commands/\__init_\_.py
        commands.start()
        main()
    except:
        futil.handle_error('run')
def stop(context):
    try:
        \# Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
def main():
    ui = None
    try:
        app = adsk.core.Application.get()
        move_camera(app, app.activeViewport)
    except:
        if ui:
ukdavewood6ZZPU
Observer
Observer
I do panning and zooming using named views - and then code like this to switch the Camera between views - with some delays in between.
for search in search2.split(';'):
                if search.upper() == "C":
                    CenterAndShowInWindowAllVisibleObjects(app)
                elif search.upper() == "V1":
                    app.executeTextCommand(u'NamedView.RestoreCamera View1')
                elif search.upper() == "V2":
                    app.executeTextCommand(u'NamedView.RestoreCamera View2')
                elif search.upper() == "V3":
                    app.executeTextCommand(u'NamedView.RestoreCamera View3')
                elif search.upper() == "P":
                    time.sleep(1)
(view in My Videos)
Jorge_Jaramillo
I can see in you script that you are running the move_camera() function from the main function in the script.
Running it from there blocks the Fusion main thread which it needs to make all the operations and update the results in the UI.
I'd suggest to implement it this way:
- start a thread from the addIn which listens to the mouse events and sends custom events to the main thread (this way it wont block the main thread)
- implement an event handler which listen from custom events and update the UI (remind that only the main thread could do so).
This two blocks need to be started from the addIn, not from the main() function as a script.
Regarding the data you receive from you mouse: could you post some samples of what it sends?
I hope this could help.
Jorge Jaramillo
