Palette to get data from python keeps looping
info83PHN
info83PHN
Trying to modified the palette / python code to :
1. Click the palette html button to activate the python script
2. python script to get some data from the Components
3. python feed the data back to the palette
4. palette to display the returned message.
added bonus would be to have the palette window display when the add-on is run.
Problem - palette displays, but when clicking on the button, it loops with the number returned from python updating all the time.
I stripped out the code for the "Send Info to HTML" add-on dropdown menu, as I want the python script to return the required info once the palette html button is clicked.
The palette code is :
<!DOCTYPE html>
<html>
    <head>
    </head>
    <body>
        <p>Click the button below to send data to Fusion.</p>
        <button type='button' onclick='sendInfoToFusion()'>Click to send info to Fusion</button>
        <p id='p1'>Ready to run.</p>
        <br /><br />
    </body>
    <script>
        function sendInfoToFusion(){
			// arg1 = 'ReadVolumes' will tell the python script which data I want returned to display on the palette.
            var args = {
                arg1 : "ReadVolumes",
            adsk.fusionSendData('send', JSON.stringify(args));
        window.fusionJavaScriptHandler = {handle: function(action, data){
            try {
                if (action == 'send') {
					document.getElementById('p1').innerHTML = data;
				else if (action == 'debugger') {
                    debugger;
				else {
					return 'Unexpected command type: ' + action;
            } catch (e) {
                console.log(e);
                console.log('exception caught with command: ' + action + ', data: ' + data);
            return 'OK';
    </script>
</html>
The python code is :
import adsk.core, adsk.fusion, adsk.cam, traceback
import json
# global set of event handlers to keep them referenced for the duration of the command
handlers = []
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
num = 0
# Event handler for the commandExecuted event - show palette, create handlers
class ShowPaletteCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            # Create and display the palette.
            palette = _ui.palettes.itemById('myPalette')
            if not palette:
                palette = _ui.palettes.add('myPalette', 'My Palette', 'palette.html', True, True, True, 300, 200)
                # Dock the palette to the right side of Fusion window.
                palette.dockingState = adsk.core.PaletteDockingStates.PaletteDockStateRight
                # Add handler to HTMLEvent of the palette.
                onHTMLEvent = MyHTMLEventHandler()
                palette.incomingFromHTML.add(onHTMLEvent)
                handlers.append(onHTMLEvent)
                # Add handler to CloseEvent of the palette.
                onClosed = MyCloseEventHandler()
                palette.closed.add(onClosed)
                handlers.append(onClosed)
            else:
                palette.isVisible = True
        except:
            _ui.messageBox('Command executed failed: {}'.format(traceback.format_exc()))
# Event handler for the commandCreated event.
class ShowPaletteCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            command = args.command
            onExecute = ShowPaletteCommandExecuteHandler()
            command.execute.add(onExecute)
            handlers.append(onExecute)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the commandExecuted event.
class SendInfoCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # Send information to the palette. This will trigger an event in the javascript
            # within the html so that it can be handled.
            if palette:
                global num
                num += 1
                palette.sendInfoToHTML('send', 'Message has been sent ' + str(num) + ' times')
        except:
class SendInfoCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            onExecute = SendInfoCommandExecuteHandler()
        except:
# Event handler for the palette close event.
class MyCloseEventHandler(adsk.core.UserInterfaceGeneralEventHandler):
    def __init__(self):
        super().__init__()
        try:
            _ui.messageBox('Close button is clicked.')
        except:
# Event handler for the palette HTML event.
class MyHTMLEventHandler(adsk.core.HTMLEventHandler):
    def __init__(self):
        super().__init__()
        try:
            global num
            num += 1
            palette.sendInfoToHTML('send', 'It has been sent ' + str(num) + ' times')
        except:
def run(context):
    try:
        global _ui, _app
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        # Add a command that displays the panel.
        showPaletteCmdDef = _ui.commandDefinitions.itemById('showPalette')
        if not showPaletteCmdDef:
            showPaletteCmdDef = _ui.commandDefinitions.addButtonDefinition('showPalette', 'Show Custom Palette', 'Show the custom palette', '')
            # Connect to Command Created event.
            onCommandCreated = ShowPaletteCommandCreatedHandler()
            showPaletteCmdDef.commandCreated.add(onCommandCreated)
            handlers.append(onCommandCreated)
        panel = _ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = panel.controls.itemById('showPalette')
        if not cntrl:
            panel.controls.addCommand(showPaletteCmdDef)
    except:
        if _ui:
def stop(context):
    try:
        # Delete the palette created by this add-in.
        if palette:
            palette.deleteMe()
        # Delete controls and associated command definitions created by this add-ins
        cmd = panel.controls.itemById('showPalette')
        if cmd:
            cmd.deleteMe()
        cmdDef = _ui.commandDefinitions.itemById('showPalette')
        if cmdDef:
            cmdDef.deleteMe()
    except:
        if _ui:
j4n.vokurka
That occurs because you are perpetually calling the sendInfoToHTML method.
Short explanation: button is pressed in palette =>
incomingFromHTML is triggerred => sendInfoToHTML() is used in handler => incomingFromHTML is triggerred again - cycle is born.
To tackle this you have to check the json data you receive from the palette and determine what has happened and if you want to react to that or not.
I have adjusted the python and javascript code because there are a lot of handlers I think you don't need right now. The logic you need starts on line 63.
palette:
<!DOCTYPE html>
<html>
    <head>
    </head>
    <body>
        <br /><br />
    </body>
    <script>
            var args = {
                data : "ButtonPressed",
            try {
                    debugger;
				else {
            } catch (e) {
                console.log(e);
            return 'OK';
    </script>
</html>
python:
import json
handlers = []
num = 0
    def __init__(self):
        super().__init__()
        try:
        except:
    def __init__(self):
        super().__init__()
        try:
            if not palette:
            else:
        except:
    def __init__(self):
        super().__init__()
        try:
            global num
            htmlArgs = adsk.core.HTMLEventArgs.cast(args)
            data = json.loads(htmlArgs.data)
            if (data['data'] == "ButtonPressed"):
                num += 1  # call your script here and retreive needed component info
            elif (data['data'] == "OK"):
                return
            else:
                # some error
                return
        except:
    def __init__(self):
        super().__init__()
        try:
        except:
def run(context):
    try:
        global _ui, _app
        if not cntrl:
    except:
        if _ui:
def stop(context):
    try:
        if palette:
            palette.deleteMe()
        if cmd:
            cmd.deleteMe()
        if cmdDef:
            cmdDef.deleteMe()
    except:
        if _ui:
info83PHN
@j4n.vokurka my sincere Thanks. I just could not understand why it was looping. Your solution worked perfectly. Thank You
j4n.vokurka
@info83PHN no problem 🙂
Also if you want to display the palette right away when the add-in is started, you can execute its command definition which will simulate user clicking the button.
Add this at the end of your run method:
showPaletteCmdDef.execute()
info83PHN
 PERFECT - Thank You - I was going to make another post for that as I could not find that solution either.
