Offsett a BRepBody
Offsett a BRepBody
florian.pommereningDGUYA
Offsett a BRepBody
I'm looking for a way to offset a temporary BRepBody by a given distance, i.e., make it larger by pushing its edges outside. Is there any way to do this with the API?
BrianEkins
The temporary B-Rep capabilities are fairly limited and do not support the ability to offset a body.  A workaround is to create a body in a base feature and then use features to create the offset. I tried some things interactively and found the Offset Face command does this when you select all of the faces of the body.  Unfortunately, I also found that the API doesn't currently support the creation of the Offset Face feature (OffsetFacesFeature).  However, I also found Offset command, which creates a new body and the API does support the creation of this feature (OffsetFeature).
Brian Ekins
Thanks. It looks like this only works on open bodies, so I'm not quite sure if I can make it work. But it looks like this is the only option.
