Occurrence creation failing: invalid argument transform
Joshua.mursic
Joshua.mursic
Hello, I am having an issue creating a new occurrence using a matrix. I am getting this error
RuntimeError: 3 : invalid argument transform
I logged the matrices but I do not understand what the issue is.
(1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0)
transformBy
(0.9999181351095504, 0.00302995523422106, 0.01243151037958249, 0.12366421759092841, 0.0030299552616395655, 0.8878563476771933, -0.4601107749884012, -1.104974592816854, -0.012431510844021457, 0.46011078801444666, 0.8877744760302924, -3.4855238784639786, 0.0, 0.0, 0.0, 1.0)
new matrix:
I am using this function to create the occurrence with the resulting matrix
newOccurence = root.occurrences.addNewComponent(matrix)
kandennti
Hi @Joshua.mursic -San.
I have tried.
It seems that the vector of each axis obtained by the getAsCoordinateSystem method must be a unit vector and each axis must be orthogonal.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import math
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        mat: core.Matrix3D = core.Matrix3D.create()
        mat.setWithArray(
                -0.012431510844021457,0.46011078801444666, 0.8877744760302924, -3.4855238784639786,
                0.0, 0.0, 0.0, 1.0
        dump_matrix3d(mat, "--before--")
        create_occurrence(root, mat)
        origin, xAxis, yAxis, zAxis = mat.getAsCoordinateSystem()
        xAxis.normalize()
        yAxis.normalize()
        zAxis.normalize()
        yAxis = zAxis.crossProduct(xAxis)
        zAxis = xAxis.crossProduct(yAxis)
        mat.setWithCoordinateSystem(origin, xAxis, yAxis, zAxis)
        dump_matrix3d(mat, "--after--")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_occurrence(
    targetComp: fusion.Component,
    mat: core.Matrix3D,
) -> fusion.Occurrence:
    try:
        return targetComp.occurrences.addNewComponent(mat)
    except:
        print("**create_occurrence_error**")
        return None
def dump_matrix3d(
    mat: core.Matrix3D,
    msg: str,
) -> None:
    print("\n" + msg)
    _, xAxis, yAxis, zAxis = mat.getAsCoordinateSystem()
    print(f"xAxis.asArray:{xAxis.asArray()}")
    print(f"yAxis.asArray:{yAxis.asArray()}")
    print(f"zAxis.asArray:{zAxis.asArray()}")
    print(f"xAxis.length:{xAxis.length}")
    print(f"yAxis.length:{yAxis.length}")
    print(f"zAxis.length:{zAxis.length}")
    print(f"xAxis-yAxis:{math.degrees(xAxis.angleTo(yAxis))}deg")
    print(f"yAxis-zAxis:{math.degrees(yAxis.angleTo(zAxis))}deg")
    print(f"zAxis-xAxis:{math.degrees(zAxis.angleTo(xAxis))}deg")
Joshua.mursic
Works perfectly as always @kandennti, thank you very much!
