Multi file upload .stp
nubrandao
Message 1 of 1
nubrandao
I saw this script in youtube, wanna to share, dont know if was already here.
# Created by Portland CNC
import adsk.core, adsk.fusion, traceback
import os
def run(context😞
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        # Counters for imported files and a list for failed imports by name
        success_count = 0
        fail_count = 0
        failed_files = []
        # Create a file dialog to select STEP, IGS files
        fileDialog = ui.createFileDialog()
        fileDialog.title = 'Select STEP, IGS Files'
        fileDialog.filter = 'STEP Files (*.stp; *.step; *.igs; *.iges)'
        fileDialog.filterIndex = 0
        fileDialog.isMultiSelectEnabled = True
        dialogResult = fileDialog.showOpen()
        if dialogResult == adsk.core.DialogResults.DialogOK:
            filenames = fileDialog.filenames
            for filename in filenames:
                try:
                    # Extract the file name without extension to use as the component name
                    componentName = os.path.splitext(os.path.basename(filename))[0]
                    # Import the file directly into the root component
                    importOptions = app.importManager.createSTEPImportOptions(filename)
                    app.importManager.importToTarget(importOptions, rootComp)
                    # Find the last created occurrence and rename it
                    lastOcc = rootComp.occurrences[-1]
                    lastOcc.component.name = componentName
                    # Increment successful import count
                    success_count += 1
                except Exception as e:
                    # Increment fail count for this file and add its base name to the failed_files list
                    fail_count += 1
                    failed_files.append(os.path.basename(filename))
                    print(f'Error importing {os.path.basename(filename)}: {str(e)}')  # Optional: Log the specific error to the console
            # Modify the message box to include information about failed file names
            if failed_files:
                failed_message = '\n'.join(failed_files)
                ui.messageBox(f'{success_count} files imported successfully\n{fail_count} files failed\n\nFAILED:\n{failed_message}')
            else:
                ui.messageBox(f'{success_count} files imported successfully.\n{fail_count} files failed')
        else:
            ui.messageBox('No file selected')
        if ui:
            ui.messageBox(f'Failed:\n{traceback.format_exc()}')
Replies (0)
