move(targetFolder) method on dataFile object broken?
SendItCNC
SendItCNC
dataFile.move(targetFolder) causes the dreaded "A software problem has caused Fusion to close unexpectedly" message. Ouch.
dataFile.copy(targetFolder) works just fine.
Here's a minimal amount of code that demonstrates the problem. The important part is the last line where Fusion blows up. Change move() to copy() in the last line and it works fine.
Any ideas for a workaround? I'd really like to move some dataFiles.
Thanks, -Dave
p.s. Wouldn't it be nice to have a itemByName() method on the dataFolders and dataProjects objects?
app = adsk.core.Application.get()
ui = app.userInterface
projectName = 'Test'
project = None
for checkProj in app.data.dataProjects:
    if checkProj.name == projectName:
        project = checkProj
        break
if project is None:
    ui.messageBox("Project '{}' not found".format(projectName), '', adsk.core.MessageBoxButtonTypes.OKButtonType,    adsk.core.MessageBoxIconTypes.InformationIconType)
    return
testFileName = 'TestFile'
testFile = None
for checkFile in project.rootFolder.dataFiles:
    if checkFile.name == testFileName:
        testFile = checkFile
if testFile is None:
    ui.messageBox("File '{}' not found".format(testFileName), '', adsk.core.MessageBoxButtonTypes.OKButtonType, adsk.core.MessageBoxIconTypes.InformationIconType)
    return
testFolderName = 'TestFolder'
testFolder = project.rootFolder.dataFolders.itemByName( testFolderName )
if testFolder is None:
    ui.messageBox("Folder '{}' not found".format(testFolderName), '', adsk.core.MessageBoxButtonTypes.OKButtonType, adsk.core.MessageBoxIconTypes.InformationIconType)
    return
testFile.move( testFolder )
kandennti
Hi @SendItCNC .
I tried it and the move method crashed Fusion360 for me too.
I think it is probably a bug.
BrianEkins
I can reproduce this and will make sure a bug gets filed.
Brian Ekins
Dave.SendItCNC
@BrianEkins
Interesting update on this...
dataFile.move() is now much improved and works... mostly.
If the file to be moved has been saved by Fusion, it seems to work perfectly.
However, in the case of files that were just uploaded (from .f3d's), move() throws an exception: Run time error 2, validation, res. The move is actually completed, despite the exception.
Interestingly, copy works fine on such files.
-Dave
Dave.SendItCNC
Actually, I'll withdraw this pending further investigation.
It appears that the explanation may be that  since the move() is on a file which is the subject of an iterator, the iterator becomes invalid as a result of the move(). I'm seeing it work in cases where the iterator  is over dataFiles.asArray() rather than dataFiles.
