Migrating adding from Design workspace to manufacture model
rbackman07
rbackman07
Hi there, I have a script that is running in the design workspace but now that fusion has nesting in manufacture model I want to move it there. but the addin is not showing up there by default. Can anyone give me a hint as to what needs to change to make this work?
For example to toolbar/panel I was using before is SolidCreatePanel
ui.allToolbarPanels.itemById('SolidCreatePanel')
also assuming it has a differnt timeline?
app = adsk.core.Application.get()
design = app.activeProduct
timeLine = design.timeline
is the rootcomponent the same?
design.rootComponent
Any other gotchas for working with manufacture models?
I am super excited about the arrange feature! any help is greatly appreciated.
KrisKaplan
The Manufacture workspace is related to the CAM API. These are types defined in the adsk.cam namespace.
The active product in this case is adsk.cam.CAM (instead of adsk.fusion.Design when you are in the Design workspace).
More complete documentation is a work in progress. But I would suggest poking around on the Python command line in Fusion.  For example, you can use the following to get a list of panels in the current workspace.
ui = app.userInterface
[p.name for p in ui.activeWorkspace.toolbarPanels]
Or to get a list of members with documentation on an object (or function) you can use the 'help' command.
help(app.activeProduct)
Or to just get a smaller list of member names available:
dir(app.activeProduct)
Kris
Kris Kaplan
rbackman07
Thanks Kris!
