Lost access to Python editor and interpreter
After no problems editing and running scripts since originally installing Fusion, suddenly . . .
When I select a script in the Add-Ins dialog and choose Edit, I get a fleeting message:
  Dialog Title: C:\WINDOWS\system32\cmd.exe
  Dialog Content:
        Installing extensions...
        Extension 'ms-python.python' is already installed
But . . . nothing else happens.
Run does nothing.
Just opening a .py file in the scripts folder, opens the editor but reports no interpreter installed.
I uninstalled Fusion and Visual Studio Code and reinstalled Fusion.  Upon first try to Edit a script in the Fusion dialog, it prompted to download Visual Studio (just as it had upon original installation) and I ran the download.
No change in results.
Thanks for help here
Trying to get a completely fresh Fusion install, uninstalled Fusion, then renamed the Fusion 360 folders in AppData Local and Roaming to hide them.
Downloaded a fresh installer from my account
Installed this new download.
Now Fusion won't start.  Asks for my email and password and, after entering, get Sign in Failure; There was an error while logging in to Fusion 360
Best way to get a completely fresh Fusion installation?
This time, hid the  Autodesk folders (one level above previous) in AppData Local and Roaming.
Now Fusion installs and runs, but . . .
Same problem with Python access as in the original post.
Anything else to hide before installing Fusion?
Correction . . . Now (with new Fusion installation)
  • Still can not edit scripts from API dialog
  • But . . . scripts do run
  • Create new script creates the default script which does run but can't be edited
Note: Using Windows 10
Also:  Talked with a non-Fusion user who just Installed Fusion to help me test.  Same behavior that I experience.
BrianEkins
I'm having the same problem.  I downgraded the Python extension to the previous version and that seemed to fix it.  Seems to be an issue with the new extension so there's either a problem with it or something changed that affects how Fusion talks to it.
Brian Ekins
Brian,
Thank You.  Worked.
