Lofting two lofts through API
BradAndersonJr
BradAndersonJr
Greetings!
I've hit a wall with a script I'm working on.  I've created 4 lines, and from them created two pairs a distance apart from each other.  Now I'm trying to loft to two together to form a solid shape.  I'm lost at how to define the initial lofts to be called upon for the 3rd loft.  Very novice to scripting, I apologize for my 'lingo'.  Here's part of the code I have so far for the lofting.
        # Create input
        loftFeats = rootComp.features.loftFeatures
        loftInput1 = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj1 = loftInput1.loftSections
        loftSectionsObj1.add(openProfile2)
        loftSectionsObj1.add(openProfile1)
        loftInput1.isSolid = False
        # Create
        loftFeats.add(loftInput1)
        # Create input
        loftInput2 = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj2 = loftInput2.loftSections
        loftSectionsObj2.add(openProfile3)
        loftSectionsObj2.add(openProfile4)
        loftInput2.isSolid = False
        # Create
        loftFeats.add(loftInput2)
#        # Create input
#        loftInput3 = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
#        loftSectionsObj3 = loftInput3.loftSections
#        loftSectionsObj3.add(loftInput1)
#        loftSectionsObj3.add(loftInput2)
#        loftInput3.isSolid = False
#        # Create
#        loftFeats.add(loftInput3)
Here's the two new surfaces I'm trying to loft together.  I'm sure I just need to define each new loft as a surface, but don't know how.
Thanks for any help or guidance!
Brad
Brad Anderson Jr
Fusion 360 Hobbyist
Fusion 360 Luthiers Facebook Group
marshaltu
It would be good if you can record a video to explain what you were going to do. You can create a loft in UI according to your thoughts. Then I can probably give clues how to do same by API.
Marshal
Marshal Tu
Fusion Developer
BradAndersonJr
Hey Marshal!
I recorded a simple Screencast of the operations I'm trying to complete via the API.  I'm able to create the first 2/side lofts via my script but am stuck on how to loft the two surfaces together to create a whole object.
From what I've gathered so far, I need to specify that the newly created surfaces are BRepFaces and that's how I should call them in my 3rd loft feature.  I just have no clue how to do that in the API, yet!
Thanks for any help!
Brad
Brad Anderson Jr
Fusion 360 Hobbyist
BradAndersonJr
Brad Anderson Jr
Fusion 360 Hobbyist
BrianEkins
I believe the code below will create what you described.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        # Create a sketch and draw the four lines.
        sk = root.sketches.add(root.xYConstructionPlane)
        lines = sk.sketchCurves.sketchLines
        line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0,0,0),
                                     adsk.core.Point3D.create(1,10,0))
        line2 = lines.addByTwoPoints(adsk.core.Point3D.create(15,0,0),
                                     adsk.core.Point3D.create(16,12,0))
        line3 = lines.addByTwoPoints(adsk.core.Point3D.create(2,-1,8),
                                     adsk.core.Point3D.create(3,10,7))
        line4 = lines.addByTwoPoints(adsk.core.Point3D.create(17,0,8),
                                     adsk.core.Point3D.create(15,12,9))
        # Create a loft between two of the lines.
        loftInput = root.features.loftFeatures.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        section1 = loftInput.loftSections.add(root.features.createPath(line1, False))
        section2 = loftInput.loftSections.add(root.features.createPath(line3, False))
        loft1 = root.features.loftFeatures.add(loftInput)
        # Create a second loft between two of the lines.
        section1 = loftInput.loftSections.add(root.features.createPath(line2, False))
        section2 = loftInput.loftSections.add(root.features.createPath(line4, False))
        loft2 = root.features.loftFeatures.add(loftInput)
        # Create the loft between the two faces.
        section1 = loftInput.loftSections.add(loft1.faces.item(0))
        section2 = loftInput.loftSections.add(loft2.faces.item(0))
        loft3 = root.features.loftFeatures.add(loftInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
BradAndersonJr
Hey Brian!
Thanks for the help!  It definitely turns out it was the ' faces.item(0) ' bit that I was lacking!  Adding it to the end of each Loft "block" gave me the results I need!  I ended up with:
        # Create surface for bridge-end of fretboard
        loft1 = loftFeats.add(loftInput1)
        l1 = loft1.faces[0]
        # Create surface for nut-end of fretboard
        loft2 = loftFeats.add(loftInput2)
        l2 = loft2.faces[0]
        # Create surface using previous surfaces
        loftSectionsObj3.add(l1)
        loftSectionsObj3.add(l2)
        loft3 = loftFeats.add(loftInput3)
Thanks!
Brad Anderson Jr
Fusion 360 Hobbyist
