Loft - isClosed
Loft - isClosed
MichaelT_123
Advisor Advisor
Loft - isClosed
MichaelT_123
Hi TF360,
LoftFeature dialogue box has the 'Closed' button. I assume that as in the case of others objects/features it has API representative in the form of loftObj.isClosed property. The property is not documented, however, when invoked in the code, it does not create a single trouble. Much more,... it does nothing, contrary to its always willing to perform  'Closed' button. So it seems that everything is in place inside F360-core, but not exposed via API.
Is it the unintentional omission or there are some deeper aspects to it?
Sincerely
MichaelT
PS.
I have look at API document 2017_12 API Help_FusionAPI.
It is the external name, as it seems, there is no internal document's preamble with a title, date of creation, revision, etc., which would be nice to have.
MichaelT
BrianEkins
You're correct that the Closed setting for a loft is not available through the API.  I don't remember if that setting was available when the API design and implementation for the loft feature was done.  Whether it was an oversight in the original design or if the API hasn't been updated since that setting was added it really doesn't matter, because either way it's currently not available.
Brian Ekins
