Hi @perryK67ZX -San.
This has been my experience as well.
It's not a pretty solution, but when I set up ListItems, I first assigned an item that means unselected and made it selected.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import random
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
'id': 'kantoku_test',
'name': 'test',
'tooltip': 'test'
_dropIpt: core.DropDownCommandInput = None
_buttonIpt: core.BoolValueCommandInput = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandCreatedEventArgs):
core.Application.get().log(args.firingEvent.name)
try:
global _handlers
cmd: core.Command = core.Command.cast(args.command)
inputs: core.CommandInputs = cmd.commandInputs
onDestroy = MyCommandDestroyHandler()
cmd.destroy.add(onDestroy)
_handlers.append(onDestroy)
onInputChanged = MyInputChangedHandler()
cmd.inputChanged.add(onInputChanged)
_handlers.append(onInputChanged)
global _buttonIpt
_buttonIpt = inputs.addBoolValueInput(
"_buttonIptId",
"Change Items",
False,
global _dropIpt
_dropIpt = inputs.addDropDownCommandInput(
"_dropIptId",
"Select Item",
core.DropDownStyles.TextListDropDownStyle,
reset_items(_dropIpt)
except:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyInputChangedHandler(core.InputChangedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.InputChangedEventArgs):
global _buttonIpt
if args.input != _buttonIpt: return
global _dropIpt
class MyCommandDestroyHandler(core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandEventArgs):
adsk.terminate()
def reset_items(
) -> None:
listItems: core.ListItems = dropIpt.listItems
listItems.clear()
listItems.add("Plase Select Item", True)
numbers = [random.randint(1, 100) for _ in range(5)]
for num in numbers:
listItems.add(str(num), False)
def run(context):
try:
global _app, _ui
_app = core.Application.get()
_ui = _app.userInterface
cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
CMD_INFO['id']
if not cmdDef:
cmdDef = _ui.commandDefinitions.addButtonDefinition(
CMD_INFO['id'],
CMD_INFO['name'],
CMD_INFO['tooltip']
global _handlers
onCommandCreated = MyCommandCreatedHandler()
cmdDef.commandCreated.add(onCommandCreated)
_handlers.append(onCommandCreated)
cmdDef.execute()
adsk.autoTerminate(False)
except:
if _ui:
When I click on the "Change Items" button, the drop-down list changes and the "Plase Select Item" becomes selected.
