Keyshot Plugin Broken with May 7th 2016 release
xAragornx
xAragornx
My workflow was majorly disrupted when I went to export my studio walls and other geometry from fusion 360 to Keyshot 6.
Ever since the update which occured on Saturday May 7th 2016, the export to keyshot option(s) no longer appear. The options are normally in the Render workspace, in the toolbar dropdown section under the render option.
I already contacted Luxion and this is the first time they were notified about the issue.
My workflow is stuck until the problem is fixed. Help my Autodesk support staff...you're my only hope
brianrepp
Hi @xAragornx - take a look at this thread, it's an understood issue and being investigated:  http://forums.autodesk.com/t5/design-validate-document/keyshot-plugin-is-not-working-with-latest-upd...
